Calculator...
Check here for most things forum related... NOT stroker related!
Locked
Re: Calculator...
Mgardiner1 wrote:any light as to what has been changed? my numbers prove to be the same as before. What gives?
It was mainly a coding change. The scripting was written poorly, so i cleaned it up and made sure everything was standardized.
I also noticed that with the advance/retard feature i was dividing the value in half (when it was being calculated with IVC angle NOT duration and LSA)... and im still not quite sure why i did so.
Now that i cleaned up the code, it also seems to be a bit faster.
Mgardiner1
Stroker Displacement: 284 CI
Re: Calculator...
Post by Mgardiner1 »
um..... well great work! :-)
i miss writing code....
1bolt
Re: Calculator...
Post by 1bolt »
Anyone else notice that in the calc both 4.0 and 4.2 have the same bore size?
Simon
Re: Calculator...
Wow good eye!! i dont know how i screwed that up for so long!
Ill change it on monday. 3.915 for the 4.2 correct?
1bolt
Re: Calculator...
Post by 1bolt »
Bore for the 4.2 should be 3.75" I only noticed it today because I forgot that number and figured the calc would have it, but no luck, so I had to go digging in my own old posts :mrgreen:
Simon
Re: Calculator...
1bolt wrote:Bore for the 4.2 should be 3.75" I only noticed it today because I forgot that number and figured the calc would have it, but no luck, so I had to go digging in my own old posts :mrgreen:
Thanks again!
Re: Calculator...
I believe that the built in advance on the comp cam 68-231-4 preset is incorrect. It should be 4* advance. I emailed CompCams the other day and they replied with 4* advance. I also verified it by entering their seat-to-seat IVC (which isn't advertised on their site, but it is their camquest software), which is 52*. Using the 52* IVC I got a DCR of 8.36. Then, using the preset but with an advance of 4* instead of .5* I got a DCR of 8.36.
Re: Calculator...
SilverXJ wrote:I believe that the built in advance on the comp cam 68-231-4 preset is incorrect. It should be 4* advance. I emailed CompCams the other day and they replied with 4* advance. I also verified it by entering their seat-to-seat IVC (which isn't advertised on their site, but it is their camquest software), which is 52*. Using the 52* IVC I got a DCR of 8.36. Then, using the preset but with an advance of 4* instead of .5* I got a DCR of 8.36.
Thank you i will make that change.
Re: Calculator...
I thought i read on here (i couldnt find it again) that the value of 58cc's for the combustion chamber volume is incorrect.
Does anyone have any input to this?
Re: Calculator...
Mine measured 58.3cc after some polishing work. The 2000 FSM says 55.22cc to 58.22cc
Another thought.. it would be interesting to see different cam options listed than the three there... perhaps you could post in the forum for additional cam specs? I know a few people are running Lunati and Isky cams. I had an old list of cams in an excel file, but I can't find it now.
Re: Calculator...
This would definetly be the thread for additional cams to be added to the calculator...
Re: Calculator...
Im still waiting for more feedback on what people would like added to our calculator.
I went ahead and added a few things myself. Mainly for the initial bore and stroke measurements. I made it easier to be able to choose your target build. Like 4.7, 4.6 etc..
lafrad
Re: Calculator...
Post by lafrad »
The Calc is definately looking better!
Nice work!
Re: Calculator...
Some Other cams you can add to the calc if you want:
Comp Cams: (all 4* advance built in)
part; duration; lsa
68-115-4; 240; 108
68-200-4; 252; 110
68-201-4; 260; 110
68-232-4; 250; 113
68-239-4; 262; 111
Isky: (all 0* advance built in)
part; duration; lsa
1331M; 248; 108
133126; 262; 108
133127; 270; 109
133128; 280; 109
Lunati (all 4* advance built in)
part; duration; lsa
63500; 250; 112
63501; 256; 112
63502; 262; 112
63503; 268; 110
CR Calculator
When using the CR Calculator, I end up with 2 different dynamic numbers using the IVC and the advertised duration methods. Using the IVC I get 9.24cr/8.66 dynamic cr. Using the advertised duration I get 9.24cr and 7.6 dynamic. I also went to www.kb-silvolite.com and used thier cr calculator and got 9.24cr and 8.09 dynamic...What gives? Which one is right?
Locked
