Page 6 of 6
				Re: FNG 4.6 Long Rod
				Posted: June 8th, 2012, 9:06 am
				by dwg86
				Good to hear the stroker is running good. Yoy might want to check your valve adjustment. My RR's made no noise with a fairly agressive (fast) ramp on the cam (214 dur @ .050 / .501 lift).
				Posted: June 8th, 2012, 9:40 pm
				by Muad'Dib
				Which Magnecor's were you running? Mine have been great... i run the KV85's.. although i did break a couple because of my own stupidity. Dont try to pull them off when the engine / wires are hot
				Posted: June 11th, 2012, 3:28 pm
				by Antifreeze2
				I had the KV85's.  It was possible that they wore out from being pulled too often, but I still find that hard to excuse.
When adjusting RR's, what is the correct preload?  With empty lifters, it's 1/2 turn.  What about full?
