That is what I gathered, is that the cam is the same from 87-95 but in 91 it was installed 8* retarded. Which moved the power band up, reduced low rpm cylinder pressure and knocking, coincidentally the knock sensor that was on the 87-90 block was removed in 91.
So OEM cam options would be 87-90 old single pattern cam installed straight up.
91-95 Old single pattern cam installed 8* retarded.
96+ New dual pattern cam.
Compression Calculator Update - Version 2.0 Now Live!
TR1Hemi
