Piston pin
- laxplayermjd
Piston pin
Does anybody press their own rods and pistons at home? I would like to save as much money as possible when doing my first build. I have a way to heat the rod but as far as putting the pin in too far or not far enough is what im worried about.
BMW Master Tech
ASE Master Tech
Even BMW guys need a toy.
In process 4.6l Renix Build.
ASE Master Tech
hatem61
Re: Piston pin
I never did it but some claimed that freezing the pins in the fridge the night before helps with the fittment.
- Mgardiner1
Re: Piston pin
Don't cheap out, have a machine shop do it. You'll be mad as hell if you squash a piston or damage it in any other way
- John
Re: Piston pin
Mgardiner1 gave you some good advise. If you really are set on doing it yourself, this is how to do it. http://www.fordmuscle.com/forums/all-fo ... ation.html
- laxplayermjd
Re: Piston pin
About what would it cost for the machine shop to do it? What have you guys paid?
BMW Master Tech
ASE Master Tech
ASE Master Tech
Re: Piston pin
x2.. my machine shop only charged me $20 to put the pistons on the rods, but they also weighed each piston and rod prior to assembly so i would have to done it after they weighted it all any how. And i wasn't about to damage a $550 set of pistons trying to ham fist them in or cook a rod. This isn't the area to skimp and do it yourself.
- John
Re: Piston pin
The local rate here is $15 to remove 6 pistons and the same to mount a set. That includes the weight matching at installation.
Users browsing this forum: Google [Bot] and 4 guests
