How much will a MLS head gasket compress?
- Exos
Re: How much will a MLS head gasket compress?
National4WD (Canada) says it's "non-refundable" because it was a special order... I've spent in the area of 5000$ with them in the last year. And they had the guts to ask me for a deposit for the new gasket sets, they never asked for a deposit before when I ordered individual parts. So fudge them, I'll probly buy somewhere else.
I ordered a second P4529242 from Summit. The deal is still back ordered on P4529242, however they can get the 53010587AA with no problem. The gasket from Summit showed up today. Its the same 53010587AA in the packing but it comes with Mopar Performance decals. Any how I have two of the P4529242/53010587AA gaskets. One will be used tomorrow to check the compressed thickness using lead. I also have on order a VR gasket that was reported to be .038" thick. We will see what the P4529242 really compresses to. Its the only way to be sure.
-Chris
-Chris
- Exos
Huh? How do you check with lead?SilverXJ wrote:I One will be used tomorrow to check the compressed thickness using lead.
-Chris
- Exos
From what I know since the beginning of this thread and others, they should be both the same gasket...SilverXJ wrote:The deal is still back ordered on P4529242, however they can get the 53010587AA with no problem.
-Chris
You put lead between the block and head in an area where there is no gasket. In our case I needed to drill a few holes in the gasket to get multiple measurements. You put the gasket on, put the lead in the holes and torque it down. Remove head and measure the lead. Of course the gasket is now garbage once you are done. I'm a little concerned that it isn't .041" compressed as it is an OEM gasket. We shall find out tomorrow.Exos wrote:
Yes, they are. I meant to say the dealer is still back ordered, but they have no problem getting the OEM gasket. However, even with my 25% discount at the dealer summit was still cheaper on the MP labeled gasket.Exos wrote:From what I know since the beginning of this thread and others, they should be both the same gasket...SilverXJ wrote:The deal is still back ordered on P4529242, however they can get the 53010587AA with no problem.
-Chris
- Exos
I'm dissapointed with Mopar Performance... their head gasket is probably the same as the new OEM, their "performance" gasket set is BS, with cork gaskets and non-MLS head gasket.
I'm now wondering about lifters and springs. Maybe I should get Comp or other springs and lifters, if the quality of MP is like that.
I have no problems with their springs, and the ones comp recommends with their Jeep cams have a ridiculously high spring rate. Their original MP gasket was a composite gasket, not MLS. I really hope I don't find out that their MLS MP/OEM gasket is actually .051" compressed. I tried to pick up my Vicotr Reinz MLS gasket today and take some measurements, but they were closed when I got there. VR says it is .042" compressed.Exos wrote:I'm dissapointed with Mopar Performance... their head gasket is probably the same as the new OEM, their "performance" gasket set is BS, with cork gaskets and non-MLS head gasket.
Scratch one gasket, its .044" compressed. The blue part is the part that won't let the head gasket go down to the .041" of the steel only part. Also, the P4529242/53010587AA is the same as the Victor Reinz 54249S gasket (available from Carquest using 54249, no 'S'). They both measured .040"-.041" on the steel only area and .055"-.057" in the blue and steel sealing areas. As for the accuracy of my calipers, I used feeler gauges to check the reading on the gauge, and also used a second set of calipers. So, I feel that this is an accurate measurement of the new style P4529242/53010587AA/VR54249S head gasket. I'm rebating starting another post with this same info in it for future searches. So now I have 3 usable gaskets, the VR, the MP and the old composite .041" VR/MP gasket.
-Chris
-Chris
ive been reading posts for some time now and have gathered most all parts for my build. still havent taken block to machine shop cause im not sure on gasket thicknesses. would like to have a real tight quench. was wondering about the thinest quality gasket i could come accross. hope u figure this one out for me.
keepin the five alive!
just an FYI, the MLS gaskets *are* reusable if you don't beat them up going on and off... if you are in a pinch at least.SilverXJ wrote:Scratch one gasket, its .044" compressed. The blue part is the part that won't let the head gasket go down to the .041" of the steel only part. Also, the P4529242/53010587AA is the same as the Victor Reinz 54249S gasket (available from Carquest using 54249, no 'S'). They both measured .040"-.041" on the steel only area and .055"-.057" in the blue and steel sealing areas. As for the accuracy of my calipers, I used feeler gauges to check the reading on the gauge, and also used a second set of calipers. So, I feel that this is an accurate measurement of the new style P4529242/53010587AA/VR54249S head gasket. I'm rebating starting another post with this same info in it for future searches. So now I have 3 usable gaskets, the VR, the MP and the old composite .041" VR/MP gasket.
-Chris
what part number for one that compresses .043 .044 and whats the best place to find one
Umm.. go back about 4 posts and try reading.
Thank you for wasting bandwidth today.
give me a break ive read and drank to much for one day but dont worry i got it now
- ccpanel
- Stroker Displacement: 275
- Vehicle Year: 1950
- Vehicle Make: chevy
- Vehicle Model: truck
im trying to determine exactly which headgasket came with my felpro kit. machinist says its the 041 and im not sure. no part number on the gasket.SilverXJ wrote:Scratch one gasket, its .044" compressed. The blue part is the part that won't let the head gasket go down to the .041" of the steel only part. Also, the P4529242/53010587AA is the same as the Victor Reinz 54249S gasket (available from Carquest using 54249, no 'S'). They both measured .040"-.041" on the steel only area and .055"-.057" in the blue and steel sealing areas. As for the accuracy of my calipers, I used feeler gauges to check the reading on the gauge, and also used a second set of calipers. So, I feel that this is an accurate measurement of the new style P4529242/53010587AA/VR54249S head gasket. I'm rebating starting another post with this same info in it for future searches. So now I have 3 usable gaskets, the VR, the MP and the old composite .041" VR/MP gasket.
-Chris
where EXACTLY do i measure? it looks like a blue composite with metal rings in it. i measured the metal between 2/3 and 4/5 and it came up around 048 the blue part is around 057/058
im measuring with a micrometer not calipers.
because of some tolerance stacking and an error-i actually want the 051 gasket.
