Show your stuff...
Off topic, play nice. No Nudity, Pornographic material etc..
BLHTAZ
Show your stuff...
Post by BLHTAZ »
Let's see your Jeeps...
We have two. Both are 4.0L, but the YJ is the one that is going to be the recipient of the stroker one day.
'95 YJ - PREDATOR
'88 MJ - Mighty Joe
Re: Show your stuff...
Mines in development... but here is a pic of it before i hit a deer:
It doesnt look that pretty anymore as when i replaced the header panel i only was able to find one from a grey jeep :roll:
Basically all stock, except for basically replacing everything engine wise... Runs like a dream now with no oil leaks.
1bolt
Post by 1bolt »
daaaammm MJ's are representin' yo here's mine:
It's an 89 that I restored with a Jasper Renix not stroked yet.
Here's my Stroker (the red MJ is the same as above before I painted it in my driveway):
An old shot of my YJ which currently is a roller for the 3rd or 4th time (drive trains been pulled and swapped a few times) and has had a 4.2 a 4.0 and a 4.6 stroker. The same YJ is in my avatar pic, if you're wondering the avatar shows the TJ round headlight grille conversion which is how it sits empty engine bay and all.
The Silver Mustang next to it is my old 01 Cobra DOHC 32 valve 4.6 V8 it was a screamin fast car.
My Familly DD bought for $850 with a new 4.0 in it:
Simon
Off Topic...
$850 for that!!! Ive been looking for another XJ all over the place and the best prices i can find are around 2500 bucks! And thats even including some of the RENIX's! Damnz you!!
Jeep-Power
Stroker Displacement: 4.3
Vehicle Year: 1984
Vehicle Make: AMC/Jeep
Vehicle Model: CJ-7
Post by Jeep-Power »
I have had this CJ-7 since 1989-- it had 36K on the ticker and looked like it rolled right out of the showroom-- now has 300+!
I bit the bulle3t in '95 and installed a Electromotive "JFI" kit-- it was a two barrel TBI kit with distributorless ignition. It was far above what the carb was giving me as far as smooth operation and reliability. It did however give a little less off the line throttle response. I was OK wth t hat as it would now run up-side-down when 4 wheelin`.
In 2004 the JFI computer when on the fritz, again, and they wanted $2K+ to outfit me with a stand alone system, as they were no longer supporting the JFI system. Sooo I did a little web searching and found the Strokers yahoo! Group. I was told to get a head, manifold set, and complete wiring from a 91-95 Jeep 4.0 and slap it on my 258. Jeep life hasn't been the same since. :D
the last time I was in Paragon-- on Rattler, January 2007
Towing this thing with a non-overdrive transmission (T-18), 3.31 axles, and 34" TSL's would have been unbearable without the 4.0 head swap. I can do 65 up moderate interstate hills while towing this 1000 lb camper.
At Rausch reek this past summer, with Joanna
Under the hood...
TNT
Where's the "any" key?
Post by TNT »
It is a '89 MJ swb that is getting a '95 4.0 AW-4/NP242 combo. It's getting a HP D44 axle and a rear 9"axle with 5.13 gears. Both axles will be trussed and built strong. There will be noticably influenced with JeepSpeed and desert technologies. About 6" of lift anf 35"-37" tires will be used,
This is a photo chop kind of like what I'm building.
I'm extending the cab to use 2dr XJ doors.
Fenders will be cut for maximum uptravel with dramatically raised flares in the front.
It has 14" of clearance from the 33" tire to the flare with 6" of lift.
The rear will get a custom box basicly like this.
Here is what it looked like when I bought it.
Here is the view of it coming at you.
A side view of my deer slayer bumper on my 95 parts XJ.
Image+
I have 2 XJ's I'm using for parts. It will have all the creature comforts and will also be fully caged.
A stroker will be the icing om the cake. :mrgreen:
TNT
89 MJ ext. cab project
Life's Journey isn't to arrive at the Grave Safely in a Well Preserved Body. But Rather to Blast Full Throttle, Launch Airborne, Land Hard, Slide in Sideways, Totally Worn Out & Thrashed, Screaming Holy $hit What a Ride!
Geonovast
Post by Geonovast »
The front...Image
The back...Image
She didn't used to look this good underneath :-DImage
Yes, that is my cargo rack from my old XJ.
RIP 88 XJ 4.0 Pukey 4x4.
-Correy
91 swb Comanche Sportruck, red
2.5, 4x4 D30/D35 3.55, 5 speed
91 swb Comanche Pioneer, blue
4.0 HO, 4x2 D35 3.07, 5 speed
Comanche91
Vehicle Year: 1991
Vehicle Make: JeeP
Post by Comanche91 »
Well, since everyone is showing their MJ's, here's mine
Left
Right
HESCO 4.5 Stroker
I like chrome!
oletshot
Post by oletshot »
OK, guess it's time for this old man to learn how post pics on a forum. Here goes.
The start of all this crazy Jeep stuff. A 1990 cherokee 140k miles. Engine donated to stroker project, the rest was scrapped. :cry:
My current daily driver. 1998 cherokee 150k miles. 31" procomp's, 3.5"-4" of lift.
My son's current daily driver. 1994 wrangler 125k miles 2.5L. 32" tsl's, 3.5" lift
Ok, that wasn't so bad. Maybe this forum stuff ain't so bad. :D
'98 XJ 2-door, '94 YJ.
aaronkeiser
Vehicle Year: 1991
Post by aaronkeiser »
Sorry the pictures suck, I couldn't get my good pictures to work. This is my daily driver 91 4.0 wrangler after I put 37 MTR's on
Shark
Consistent
Consistent
Post by Shark »
that thing is clean man! nice ride.
Comanche91 wrote:Well, since everyone is showing their MJ's, here's mine
Left
Right
HESCO 4.5 Stroker
I like chrome!
'95 XJ 4door 4.0 aw4 2" 31's
Comanche91
Vehicle Year: 1991
Vehicle Make: JeeP
Thanks Tigershark. :D :mrgreen: :)
Shark
Consistent
Consistent
Post by Shark »
Comanche91 wrote:Thanks Tigershark. :D :mrgreen: :)
tell us more about your truck. what year, mods,etc. how long have you had it? was is this nice when you got it?
btw, if you aint a Gator youre Gator bait!
Comanche91
Vehicle Year: 1991
Vehicle Make: JeeP
Here's pic of how it was when I bought it from the original owner in Lynchburg, VA six years ago. Plain-Jane base nmodel, but the body was great:
Mods include:
Interior: Complete 2-DR XJ Laredo interior (buckets, door panels, full console, dash, visors, etc.); power windows/seat/mirrors; cruise, rear slider
Engine/drivetrain: Hesco 4.5L stroker, New Tom Woods driveshaft, 4.11 gears
Suspension/steering: 3" lift via new metric ton rear leafs; OME front coils; OME shocks; ZJ steering gear and sway bar; WJ LCAs
Brakes: Ford Exploder rear disks, 96 XJ booster & master
Lighting: Hella H4 headlamps & wiring harness, Perlux s/s fog lamps
Wheels/Tires: 15x8 Ravine wheels w. 31" BFG ATs
Cooling: Hesco hi-flow water pump, custom aluminum 1-3/8" single core radiator, all-electric fans
CHROME: Mirrors, door handles, wipers, tail lamps, grille, head lamp doors, bumpers, etc. (I like chrome 8-) )
oletshot
Post by oletshot »
WOW! looks way better now than when you bought it. Nice work. By the way, what was going on with the rear axle, it looks uncentered in the wheel well in the picture when you got it, better now though. Again, nice ride.
Users browsing this forum: No registered users and 37 guests
