Late model intake swap????
Rob92XJ
Where's the "any" key?
Post by Rob92XJ »
I just installed my 4.7L and 99 intake what drive belt is everyone using I have about 10 belts and none of them fit.
Re: Late model intake swap????
The same belt I was running before I switched intakes.
2045mmK6 belt with the mech fan pulley delete and running 99 intake on 96.
Mgardiner1
Stroker Displacement: 284 CI
Post by Mgardiner1 »
After buying 2 belts, i backed the adjuster all the way off and wrapped a peice of rope around the pulleys and measured how long it was. I then found a website that had the length of different belts and just picked the closest one
Rob92XJ
Post by Rob92XJ »
Sorry to clarify my Jeep is a 92 XJ and the parts dept at my job is closed as well as the parts store we deal with so I need a number or application to goto Advance or AutoZone with since the people in the stores here do not seem to know how to look anything up any other way.
Mgardiner1
My belt wound up being 95", and i just picked the closest "gator back" goodyear belt i could find since i found a listing of 6 rib gatorback belts and their effective lenghts. Autozone had them in stock.
Use a piece of string/twine/rope as i mentioned above, find out how long the belt needs to be, and then go to http://store.summitracing.com/egnsearch ... toview=sku and find the belt closest to what you need. Call your local autoparts thats open on a sunday, and give them the goodyear part number.
Comanche91
Vehicle Year: 1991
Vehicle Make: JeeP
Post by Comanche91 »
Rob92XJ wrote:Sorry to clarify my Jeep is a 92 XJ and the parts dept at my job is closed as well as the parts store we deal with so I need a number or application to goto Advance or AutoZone with since the people in the stores here do not seem to know how to look anything up any other way.
Did you also swap in the 96+ power steering pump, bracket, and idler pulley, then remove your original idler pulley? That's what I did on my 91. If so, you'll need a 99+ XJ serpentine belt.
aaronkeiser
Vehicle Year: 1991
Post by aaronkeiser »
You know whats funny? Mgardiner1 said he ended up with a 95" belt and he basically is running the same stuff as me yet it still took me 3 trips plus my dad 2 trips to the parts store to get the right belt.
Users browsing this forum: Amazon [Bot] and 4 guests
