Dizzy drive gears
Stroker Displacement: 4.9
Dizzy drive gears
Post by jsawduste »
Like to get a feel for what you folks are seeing/doing on the dizzy drive gears.
My stroker is set up with the Hesco 274/480 cam and supplied lifters. Mopar rollers but went with a lighter set of valve springs then most folks would.
Hesco did a blueprint (whatever that means) on the mellings HV oil pump.
Was`nt real impressed with how the drive gear got lubed but since stockers seem to run many a mile I compromised and used the Hesco bronze.
At about 3,000 miles the gear wore to the point that the dist. would no longer engage. Fortunately right by home.
While all the teeth of the bronze gear were worn. Approx 120* of the gear teeth had actually worn concave. As though the dizzy shaft or cam gear is slightly out or round.
As bronze is a bit more forgiving then steel to bearings and such I did replace the gear with another Hesco bronze.
The external oil line is something (Thanks DWG sp ?) I am looking real hard at. Don`t trust the copper so braided hose will be my choice.
Opinions, comments, personal experiences ?
Re: Dizzy drive gears
Post by dwg86 »
Just curious...why are you running a bronze dizzy gear? There was a thread on the Hesco forum where a guy went through 2 bronze gears then changed to a steel one, and had no problems after that.
Post by jsawduste »
dwg86 wrote:Just curious...why are you running a bronze dizzy gear? There was a thread on the Hesco forum where a guy went through 2 bronze gears then changed to a steel one, and had no problems after that.
I recall that post on the Hesco forum.
That is a good question. Bennie (or is it Benny) suggested it.
I think (my own opinion) is that with the cam failures that having a sacrificial gear of bronze was better then a steel gear that might take out the cam and send steel through the engine.
Running a bronze gear is pretty normal in a modded engine.
Bronze is a lot softer and would not cause much damage if it got into the bearings.
Bronze gears are for STEEL roller cams.
Post by John »
Some old school motors used bronze gears, Check out the older Caddy motors, non roller.
Post by jsawduste »
John wrote:Some old school motors used bronze gears, Check out the older Caddy motors, non roller.
Hi John,
from your reply, are you stating that the older Caddillac bronze gear is a replacement for the 4.0 ? Or you stating that the Caddillac`s simply used the bronze gerar.
Thanks !!
Post by John »
I know nothing about them swapping, was pointing out that bronze dizzy gears have been used on non roller cam motors.
Post by jsawduste »
John wrote:I know nothing about them swapping, was pointing out that bronze dizzy gears have been used on non roller cam motors.
Thanks for the clarification John
Users browsing this forum: No registered users and 16 guests
