Preferred oil filter?
crustodd
- Stroker Displacement: 284
- Vehicle Year: 1994
Ok Jeepers,
What the best oil filter for our strokers?
T~
T~
- Alex22
Re: Preferred oil filter?
Just about anything that isn't a Fram.
I use NAPA gold filters, which are made by Wix and I have no complaints.
~Alex
~Alex
Mobil 1 301.
- John
Also use NAPA Gold, they work well at a good price.
- RAPTORFAN85
WIX 51515. It's actualy for a ford v8 so it holds about a half a quart more and has more filter element to it...
"Strrrrroke me, stoke me...."
Billy Squire
Billy Squire
- seanyb505
- Stroker Displacement: 280ci
Does the Ford wix have the same thread dimensions? (Is it a direct bolt on?)
97 XJ 4.6
90 MJ 4.0 - sold
97 XJ 4.6
90 MJ 4.0 - sold
- Comanche91
- Vehicle Year: 1991
- Vehicle Make: JeeP
- Vehicle Model: Comanche
Purolator PL30001 PureONE (from Advance) or Wix 51515. Both the same size for the Fords, but the Purolator's rated a bit higher in filtration capability. Both bolt-ons. That reminds me - I'm due!
- RAPTORFAN85
Threads right on. Almost like it was made to fit the jeep not the ford. If someone gave you one and told you it was the right one for your jeep and you went to put it on, you would never know that it wasn't ment for it.seanyb505 wrote:Does the Ford wix have the same thread dimensions? (Is it a direct bolt on?)
Billy Squire
Billy Squire
- IH 392
Purolator PureONE PL14670, I don't know how you'd get a taller filter in there?, IIRC I ran a longer one on the the six in my '68 American when it had the six in it but the wire loom to the starter gets in the way of the short filter on the Jeep?
That 301 I was talking about is also a larger Ford app like the wix and pur, fyi.
- Comanche91
Here's a list of filters for both the 5.2" long and 6.9" long models. They all fit our thread, 3/4x16. Fram is omitted for obvious reasons.
The longer filters will not fit on my 91 because of interference with the starter loom. However they should work on the vertical config. oil filter engines.
5.178" HIGH, 3.660" DIA, 3/4-16
AC-Delco PF2
Motorcraft FL-1A
Purolator PL30001
Napa 1515
Wix 51515
Mobil 1 M1-301
6.93" HIGH, 3.660" DIA, 3/4-16
AC-Delco PF42
Motorcraft FL299
Purolator L40017
Napa 1773
Wix 51773
AC-Delco PF2
Motorcraft FL-1A
Purolator PL30001
Napa 1515
Wix 51515
Mobil 1 M1-301
AC-Delco PF42
Motorcraft FL299
Purolator L40017
Napa 1773
Wix 51773
I don't understand that. I have heard that before too. However, I have the horizontal oriented filter (points reward) and I don't have any interference with the starter wires. Sure, if I dropped the filter while removing it, the filter would land on the starter solenoid, and perhaps come into contact with the wires.Comanche91 wrote: The longer filters will not fit on my 91 because of interference with the starter loom. However they should work on the vertical config. oil filter engines.
- Comanche91
I'm saying there's not enough room on my 91 to push the 6.93" long filters back far enough to get the thread pipe into the filter hole w/o hitting the starter wire. The 5.178" long filters do just fit though.
- IH 392
The Purolator PL14670 is about 3 1/5" tall and it's physically touching the wire loom as it sits, and it's right in line with the center of the filter, where are you going to put a taller filter in there???
- Mgardiner1
Quick question on the picture posted above.... Is that your stock filter configuration?
My Renix engine, AND my 91 HO had a right angle adapter, that would position the filter in a more upright position. I removed it and used the threaded tube to make it like the configuration that you have pictured. I didn't like the upright angle, felt that it could allow oil to drain back into the crankcase with the engine being off for awhile. Not to mention BOTH engines had decent leaks from the adapters o-rings, so i figured it would be one less potential leak in the future
Users browsing this forum: Amazon [Bot], Google [Bot] and 7 guests
