A very budget stroker from Russia
darkcorp
Vehicle Year: 1999
Vehicle Make: JEEP
Vehicle Model: GCh 4.0
Re: A very budget stroker from Russia
Post by darkcorp »
Yup!
HCE
Vehicle Year: 2004
Vehicle Model: cherokee
Post by HCE »
That's impressive. Thanks for the pictures
darkcorp
Vehicle Year: 1999
Vehicle Make: JEEP
Post by darkcorp »
They made a set of 8 for me, because two of them were overheated while setting right temperature:
Stroker runs great, so much power although I haven't tried to push it more than 2000 revs yet (only 350 kms now).
Light pinging on EU 95 octane (US 89 octane) under moderate throttle (63mm) when engine is hot. I hope to solve it by using cooler spark plugs NGK ZFR6F-11. No pinging on LPG. My CR is 10.1:1.
There is a ticking noise coming from one bad lifter on #6 cylinder (all lifters are new, preload is checked and set to 1.0-1.5 mm by using 1.0 mm shims under rockers). Is there any chance to fix it without disassembling the head?
Strong Poster
Strong Poster
Post by Russ Pottenger »
jsawduste wrote:I think you should have listened and returned 677AP`s and ordered pistons from Russ or other supplier with a larger dish volume.
I know this build was done with financial considerations,
but many of us were trying to offer you good advice.
A short rod no quench with a 10.0:1 static compression ratio will not run on a low octane fuel.
You'll need to either increase the octane level of your fuel or lower the static compression ratio.
That said, I can only admire and appreciate the obstacles that you have to go through to buy parts and and do the necessary machine work build an engine in Russia.
I get pretty decent international shipping rates. I'll be more than happy to help in anyway that I can if you ever need anything.
Russ
darkcorp
Vehicle Year: 1999
Vehicle Make: JEEP
Post by darkcorp »
My long term corrections are +7% when idling, so 24 lbh Bosch 0280155784 injectors seems a little bit small for my engine and I need 26 lbh Bosch 0280155849 injectors.
darkcorp
Vehicle Year: 1999
Vehicle Make: JEEP
Post by darkcorp »
Hi, guys!
I've run my stroker 2000 kms already.
I have moderate pinging while running on regular gasoline. Long term OBD corrections are +7-8%.
So I've made adjustable MAP. Set it to 5.2V - much better! Then set it to 6.0V - pinging is gone. Then decreased voltage to 5.8V - no pinging at all. I'm going to decrease MAP voltage till pinging comes back again and raise up a little.
So my 24 lbh Bosch 0280155784 injectors seems small for my engine so I'm already to order larger 0280155849 or 0280155865 injectors. Which one do you recommend?
darkcorp
Vehicle Year: 1999
Vehicle Make: JEEP
Post by darkcorp »
Wow, seems like Bosch 0280155784 are not 24lbs. According to this
http://www.jeepforum.com/forum/f13/defi ... cs/1305456 they are rated 22.6 lbs:
Bosch 0280155784; 20.2lb/hr @ 39psi & 22.6lb/hr @ 49psi
So they are a good upgrade for stock engine but not enough for a stroked.
darkcorp
Vehicle Year: 1999
Vehicle Make: JEEP
Post by darkcorp »
D'you know that new KB Icon 944's have a hole so you don't need to take off excessive amount from rod?
Users browsing this forum: No registered users and 37 guests
