Adjustable map sensor
Booboo23
I recently purchased someone else's project, the engine was modified and the seller told me I would need a adjustable map sensor. I understand what it does but do not know where to purchase one and am a little confused on how to install. Any help would be appreciated
- IH 392
Re: Adjustable map sensor
As far as I'm aware you have to build one?
http://www.angelfire.com/my/fan/MAP_adjuster.html
- SkylinesSuck
Somebody used to sell one. RockIt? Can't remember, it's been a while. You could also do an SAFC install. It's basically a super duper MAP adjuster. I just took mine out (hopefully getting tuned soon) and will be putting it up for sale when It around to it.
- SkylinesSuck
It was TurboCity that made them. Looks like they aren't around anymore.
Booboo23
Anyone you know might make one
Booboo23
Safe - does anyone make one of those
Booboo23
Sorry - SAFC
http://strokedjeep.com/regulator.html
Not a fan but Leigh sells them. At least he has them on his site.
I have one that has never ben used if I can find it.
- SkylinesSuck
https://www.google.com/search?q=safc+2& ... e&ie=UTF-8Booboo23 wrote:Sorry - SAFC
Like I said, I think mine will be for sale soon.
- SkylinesSuck
- Muad'Dib
A little late to the party here but its a little concerning that you would add something after being told by a PO that you needed to do so. Do you understand why you need to? Is there a specific issue you need to combat?
Its important to understand the why before you go out and do something. typically an adjustable MAP isn't something you just throw at a problem and pray it fixes it.
JohnnyBertone
- Stroker Displacement: 4.0
- Vehicle Model: WJ
I had contacted the guy that makes them on Leigh performance. they were about $35 posted on the site. he told me he wasn't sure when he'd be making another batch of them so he couldn't give me an estimated time of when they'd be available. I came back and told him I'd PayPal him $60 to make me a one off, kind of like an offer he couldn't refuse. had it in the mailbox in a week.
very nice guy and works very well.
I tried making one myself a little over a year ago using the instructions on angel fire (I think I'm not sure) and grounded out the 5V from my computer and fried it. ($600 later) id rather pay someone to make one I know works rather than grenade my ECU again
JohnnyBertone
- Vehicle Model: WJ
I agree. the computer uses a factory programmed fueling table to keep the air fuel ratio as close to 14.7 (claimed as "perfect") as possible, until ~70% Throttle. Then it uses readings from the Manifold air pressure sensor (MAP) and adjusts the injector bursts accordingly. the MAP sensor works by taking the 5V reference from the computer, modifying that voltage by (x)% depending on the reading from the sensor, and sends it back to the computer. by changing the input voltage to the sensor, it will still modify it by (X)% but has a different number to start with. Higher voltage going in (5.2-5.5) Will richen the mixture, lower voltage (4.9-4.7) will lean out the mixture.Muad'Dib wrote:A little late to the party here but its a little concerning that you would add something after being told by a PO that you needed to do so. Do you understand why you need to? Is there a specific issue you need to combat?
so knowing how this adjustor works you now need to know what the PO is trying to bandaid by throwing an adjustment at the motor. if it's a lean condition it could mean you have clogging injectors, or failing o2 sensors (upstream which monitors the AFR).
JohnnyBertone
- Vehicle Model: WJ
also it is dangerous to modify the AFR without a Wideband o2 to monitor the radio. if you go too lean you'll fry your pistons and cook your head. if you go too rich you'll wash your cylinders and lose a lot of power, and possibly clog your cats (if they still exist). the MAP adjustor probably* won't modify it outside safe AFR towards the lean side, but it should still be monitored and adjusted in very tiny increments.
*-don't hold me to it if it does.
- darkcorp
- Vehicle Make: JEEP
- Vehicle Model: GCh 4.0
Hi!
Why using Adjustable map sensor we modify suppliing voltage, not signal direct to ecu?
