Desk top dyno
Re: Desk top dyno
The first screenshot is a bone stock '00-'04 4.0.
The second screenshot is the same engine bored/stroked to 4.6L but otherwise internally stock (i.e. stock unported head, stock cam). A header-back exhaust is the only external performance mod, with the stock airbox and stock TB used.
bigal389
Vehicle Year: 2004
Vehicle Model: Wrangler X
Re: Desk top dyno
Post by bigal389 »
That's basically the same thing I had, Just a little different compression and a ported head. It amazes me what you gain in torque by stroking an engine.
Al
Re: Desk top dyno
bigal389 wrote:That's basically the same thing I had, Just a little different compression and a ported head.
The second screenshot is with a stock unported head. A ported 0331 head would have added another 10hp, making the maximum 236hp.
bigal389
Vehicle Year: 2004
Re: Desk top dyno
Post by bigal389 »
I used cam specs at 50 so mine were a little different than yours. When I ran some of the aftermarket cam specs I was surprised that the late stock cam made as much or more torque than a lot of them.
Al
johnj92131
Re: Desk top dyno
Post by johnj92131 »
bigal389 wrote:I used cam specs at 50 so mine were a little different than yours. When I ran some of the aftermarket cam specs I was surprised that the late stock cam made as much or more torque than a lot of them.
Al
It would be interesting if you would post the results you got with the different after market cams. Really would love to see how different after market cams compare with no other changes.
Now, I understand the stock engine is optimized for emission results and the stock cam is also optimized to give decent performance and optimal emissions. So an engine tuned for best emissions may not show off the best part of an after market cam shaft.
bigal389
Vehicle Year: 2004
Re: Desk top dyno
Post by bigal389 »
When I get home this evening I'll run a couple of the aftermarket cams with my stroker specs as a baseline and post them here.
Al
bigal389
Vehicle Year: 2004
Re: Desk top dyno
Post by bigal389 »
bigal389
Vehicle Year: 2004
Re: Desk top dyno
Post by bigal389 »
As you can see on the sims the Jeep cams seem to put out the most torque for what they are.
Add a little Lif and their may be even more available.
I'll run those later.
Al
bigal389
Vehicle Year: 2004
Re: Desk top dyno
Post by bigal389 »
Can anyone explain why my attachments are sideways?
Al
SkylinesSuck
Re: Desk top dyno
Post by SkylinesSuck »
iPhone?
bigal389
Vehicle Year: 2004
Re: Desk top dyno
Post by bigal389 »
Yep. Why does it do it?
Al
jeepxj3
Vehicle Model: xj
Re: Desk top dyno
Post by jeepxj3 »
-bigal389-- Is it Big Al or is it Bi Gal?? :huh:
Can you redo the Mopar 28 and Comp 232 with 1.7:1 rockers which will add about 6.25% more lift.
Thanks.
bigal389
Vehicle Year: 2004
Re: Desk top dyno
Post by bigal389 »
It's Al lol
I will redo them tonight.
SkylinesSuck
Re: Desk top dyno
iPhones suck is the quick answer.
Apple wants you to do everything their way using all of their software, hardware, and accessories. They don't play well with pretty much every other format in the world. I'm on many different boards and every time I see pics like that, the reason always turns out to be because iPhone. I'm sure there is a way to fix it using an iPhone, but I don't know how as I've never used one for more than s couple of minutes.
bigal389
Vehicle Year: 2004
Re: Desk top dyno
Post by bigal389 »
Mopar 228 with 1.7 rockers.
Doesnt really increase peak torque but does increase at other RPMs
Mopar 229 with 1.7 rockers, same as above.
Al
Users browsing this forum: Ahrefs [Bot], Amazon [Bot] and 1 guest
