ok everything begin in fall 2013, i begin to search for a supercharge......... i always had a look on the Avengers, but i found also some adapter to install MP90. My first try was to found a used Avengers, because, it a bolt on, a probably picking a good existing setup.
in spring 2014 i found one from a 2003, come with 2 computer, 2 pulley, 2 set of injectors....so a lot of part to be able to found the right setup.
between spring 2014 and spring 2015, i search for add on, for tuner, for answer to be ready !
in february, i begin to mount the setup on a dummy 4.0L
i put the SC, a JBA headers, i ceramic coated (vht) a OEM intake i have in stock
My LJ 05 supercharge project
- quebec4x4
- Stroker Displacement: 242
- Vehicle Year: 2005
- Vehicle Model: LJ
LJ 2005 4.0L SC, 6spd Atlas IV, D44 4.88 ARB, .....
RAM 2500 5.9L 6spd 2wd Edge with Attitude, Banks brake ...
- quebec4x4
- Vehicle Model: LJ
Re: My LJ 05 supercharge project
after that, i prepare my Jeep block to receive it.
i do a intake exhaust matching, change the TH housing, make a custom downpipe without cat, 02, and with wideband port.
- quebec4x4
- Vehicle Model: LJ
and the build continue !
- quebec4x4
- Vehicle Model: LJ
and continue ....
- quebec4x4
- Vehicle Model: LJ
and the finish touch !!
U-BIT airaid kit
U-BIT airaid kit
jeepxj3
- Vehicle Model: xj
What controller are you using? DiabloSport? How much can you change with it?
- quebec4x4
- Vehicle Model: LJ
some Dyno improvement
- quebec4x4
- Vehicle Model: LJ
some graph of satherday
green line is mine, with the actual setup
4.0L, 6 speed, 4.88 37" tire
the red one, a Sprintex in a 2006 Rubicon with manufacturer tune
4.0L, 6 speed, 4.10 36" tire
- quebec4x4
- Vehicle Model: LJ
my tuner use CMR thru Diablo T1000jeepxj3 wrote:What controller are you using? DiabloSport? How much can you change with it?
change, probably my tuner will come here answer it. i built the jeep, bought the part, but the tuning part was left to one of my friend.
