Custom Cam grind numbers
akadeutsch
- Vehicle Year: 1981
- Vehicle Model: CJ8
I'll be the first to admit that I have little knowledge of what these number mean. So I thought I would ask some people who might be able to help me out. The lift is +.019(intake) and +.024(exhaust) over the OEM Cam. Could I still use stock valve springs, or would they bind?
This custom grind is offered by Clegg.
akadeutsch
Re: Custom Cam grind numbers
I forgot to add the photo.
the grey ghost
- Stroker Displacement: 4.611
- Vehicle Model: comanche
I thought the stock valve lift was something like .428?
akadeutsch
The 96-04 OEM cam had .408" intake .414"exhaust lift. This Clegg cam is .427" .438". Will my stock springs bind?
The springs won't bind but I would also ask the recommended loads as that is very important as well.
akadeutsch
This is important to avoid float?
If you like your valves in the unbent form, yes.
akadeutsch
I see. I had all of the springs tested today at the machine shop. They tested a little low....68 lbs at whatever compression distance was stated in machinist's book. I forgot the exact numbers but they compressed each spring to a certain distance and measured the force it took to get there. They were a couple of pounds short. It took on average 68 pounds to compress them and it was supposed to take 71-79 pounds. My machinist gave me some .030 shims to put under the springs. And that brought them into acceptable range. But for the cost of new springs I think that I'll just replace them.
