Fuel Tank or Pump for CJ
XJ2CJ
- Stroker Displacement: 4.5
- Vehicle Year: 1981
- Vehicle Model: Cj7
I'm trying to find the right size tank for a CJ7 that has a built in pump that will work with 96+ FI systems. Has anyone found a good way of doing this?
Re: Fuel Tank or Pump for CJ
The CJ`s never had a FI system and all of them relied on the mechanical pump on the block.
Having said that I have had success using the 87-90 YJ steel 15 gallon tank in a CJ frame. Not a "bolt in" but fit pretty well. Now you have the in tank pump and sender asm.
XJ2CJ
I didn't know those tanks had a pump. I'm assuming I'll need a return line from the fuel rail?
Yes
and may I suggest Chris at http://www.cfoffroad.com/index.html He would have everything you might want. Tell him I sent you.
XJ2CJ
jsawduste wrote:The CJ`s never had a FI system and all of them relied on the mechanical pump on the block.
Just to make sure, this tank will fit the newer round pump/sending units from a cherokee or wrangler? I hate to go to 15 gallons, but the price looks a lot better than a 4-500.00 custom tank.
I6FAN
- Stroker Displacement: 4.2
- Vehicle Year: 1987
- Vehicle Model: wrangler
[XJ2CJ wrote:I didn't know those tanks had a pump. I'm assuming I'll need a return line from the fuel rail?
I believe he's referring to the 87-90 YJ's with the throttle body injected 2.5l four cylinder not the 4.2l, so you would be looking for the 2.5l tank(?).
XJ2CJ
I6FAN wrote:jsawduste wrote:The CJ`s never had a FI system and all of them relied on the mechanical pump on the block.
Having said that I have had success using the 87-90 YJ steel 15 gallon tank in a CJ frame. Not a "bolt in" but fit pretty well. Now you have the in tank pump and sender asm.[XJ2CJ wrote:I didn't know those tanks had a pump. I'm assuming I'll need a return line from the fuel rail?
That's what I think the 15g tank is from. I just want to make sure it will fit the Cherokee fuel pump. I've been trying to figure out ways to fit the cherokee tank, but I would end up modding the rear crossmember, and possibly the one in front of the tank as well to make it work. I'll be running wider than stock axles so I could route the exhaust outside the frame rail, but I would have to drop the tank to remove the tub. And the rear cross member is pretty shot so cutting some of it out wouldn't be a problem as I'm going to be redoing it anyways.
But the 15g tank is a nice fit without the custom tank option or modded frame.
I was not as specific as I could have been but yes I am talking about the steel 15 gallon with the round sender for/from a 2.5 YJ.
Users browsing this forum: Ahrefs [Bot] and 3 guests
