2001 jeep cherokee tuning
Xj01
Stroker Displacement: 4.0
Vehicle Year: 2001
Post by Xj01 »
Hey guys, new to this forum. I have a 2001 cherokee 4.0, does any one offer any real tuning like SCT hand held tuners? Thanks!
Re: 2001 jeep cherokee tuning
Yes. Contact Chris at [email protected]. He does a great job.
Xj01
Vehicle Year: 2001
Post by Xj01 »
Do u have an sct tune on your jeep?
yes.
wjtom
Vehicle Year: 2001
Vehicle Model: wj
Post by wjtom »
Id use flyin ryan but that just me.Absolutely great results!!!!!!
Xj01
Vehicle Year: 2001
Post by Xj01 »
I've contacted both of them :banana: it's looking good
Retlaw01XJ
Vehicle Year: 2001
Post by Retlaw01XJ »
I should have my '01 done too. Runs pretty good, but has a rough cold start-up and lo rpm isn't very smooth.
What's the expected cost for a tune?
Where are you guys with the mini-cat exhaust manifolds installing the O2 senor? There's practically no room to add one before the mini-cat.
I tried replacing the original and feeding the signal from the AFR gauge back to the stock wiring, but it resulted in O2 sensor error codes every few days, even with a dummy O2 sensor heater wired in.
Walt K
Eastern Pa
Retlaw01XJ wrote:I should have my '01 done too. Runs pretty good, but has a rough cold start-up and lo rpm isn't very smooth.
An large duration cam can throw the PCM a loop... as well as incorrect sized injectors. Cost is typically around $300 + SCT if you want to go that route.
Thats what i would have recommended.. do you know the code?
Xj01
Vehicle Year: 2001
Post by Xj01 »
Retlaw what all do I have done to your engine?
Retlaw01XJ
Vehicle Year: 2001
Mild 4.6 build with Icon pistons, Crower 44243 cam, a little head porting on a 2004 head, stock exhaust to a Borla cat-back system, and still stock air intake. Injectors are Neon 784's that are a little lean at start-up until the injector heater warms up (about 1 minute)....that seems to cause injector heater codes, and sometimes a misfire code. Happens more in winter that summer.
Which SCT product will work with a Jeep? I do have an Innovate Motorsports AF gauge I can do data logging with.
Thanks.
Walt K
Eastern Pa
Xj01
Vehicle Year: 2001
Post by Xj01 »
[email protected] contact Ryan I've been talking with him to get my jeep tuned with a real tune ! Believe it's a SCT 3200 but it's no good unless u get a custom tune installed in the device.
