I have tried to search/look and can't find what are the exact specs for the Stock valve springs and the Mopar Perf 5249464 valve springs.
Here is what I have found-
[email protected]", [email protected]"(0.424"lift), [email protected]"(0.440"lift), bind at 1.140", safe to 0.440"lift, 295-327lb/in.
MP5249464- [email protected]", [email protected]"(0.424"lift), [email protected]"(0.450"lift), [email protected]"(0.500"lift), safe to 0.525"lift, 270lb/in.
Does anyone know the exact specs? @1.64"installed height and spring rate?
I found some beehive springs with the following specs as possible swaps ?-
#1213-- [email protected]", [email protected]"(0.500"lift), 191lb/in. -probably just a little lite
#1214- [email protected]", [email protected]"(0.500"lift), 275lb/in. -?just right?
I am looking for valve springs that will let the cam live at 0.518" lift. Any Ideas?
Stock and MP Valve Spring Specs ?
jeepxj3
- Vehicle Model: xj
beiwulf
- Vehicle Year: 1995
- Vehicle Make: ZJ
- Vehicle Model: Laredo
Re: Stock and MP Valve Spring Specs ?
not sure if this is the information you seek but here are some specs for stock 4L i6
Valve Springs
Free Length (Approx) ….. 46.22 - 47.65 mm (1.82 - 1.876in.)
Spring Tension --
Valve Close ……………316 to 351 N @ 41.656 mm
_____________________ (71 to 79 lbf. @ 1.64 in.)
Spring Tension --
Valve Open ……………898.6 to 969.7 N @ 30.89 mm
______________________(202 to 218 lbf. @ 1.216 in.)
Inside Diameter ………….21.0 mm to 21.51 mm
_________________________(0.827 to 0.847 in.)
Brian
Valve Springs
Spring Tension --
Spring Tension --
Brian
jeepxj3
- Vehicle Model: xj
Thanks, that helps.
STOCK---60-71-79[email protected]", 184-202-218[email protected]"(0.424"lift), [email protected]"(0.440"lift), bind at 1.140", safe to 0.440"lift, 295-327lb/in.
RenoF250
- Vehicle Year: 1985
- Vehicle Model: CJ7
Rockauto shows 2 springs 1.8 and 2.1" free length. Mine were 2.1"beiwulf wrote:not sure if this is the information you seek but here are some specs for stock 4L i6
Valve Springs
Spring Tension --
Spring Tension --
Brian
Mopar performance:
Free length: 2.06"
Rate: 271
113#@1.64"
225#@1.228"
232#@1.205"
Free length: 2.06"
Rate: 271
113#@1.64"
225#@1.228"
232#@1.205"
beiwulf
- Vehicle Make: ZJ
found this thread… hope it helps.
http://board.moparts.org/ubbthreads/sho ... 083&page=0
Parts reference on thread
Mopar performance:
P5249464 springs
P4876062 springs
Hughes Engines:
HUG 1110 springs
Mopar performance:
P5249464 springs
P4876062 springs
Hughes Engines:
HUG 1110 springs
Users browsing this forum: Ahrefs [Bot], Bing [Bot] and 3 guests
