Synchros high performance
- Stroker Displacement: 5.0
Hello everyone
I have a Jeep Wrangler 4.0 model 1993 stroker
I need to :
Manual Transmission Synchros For high performance ( stroker )
Any idea plz !
I need to :
Any idea plz !
Re: Synchros high performance
Writing in English would help.
- IH 392
I'd start with REDLINE "MTL" and see how it works?
What's the problem!jsawduste wrote:Writing in English would help.
I need this piece For high performance
And we were supposed to figure that out by your first post ?stroker wrote:What's the problem!jsawduste wrote:Writing in English would help.
Sorry my crystal ball is broken.
I believe English isn't his native language as his IP isn't from the US.
I don't know of any high performance synchros for the AX transmission.
Thanks Chris, I like manual transmissions and enjoy working with them. However OP`s post left a lot of unanswered questions. Thanks for clearing things up.SilverXJ wrote:I believe English isn't his native language as his IP isn't from the US.
Thanks...
- Stroker Displacement: 4.611
- Vehicle Model: comanche
If your dead set on getting a stronger set, there is a company in Minnesota that will cryo/harden anything you want, I would suggest breaking them in first, so it shifts a little easier, or call the company that builds the terminator with intent to buy and ask a whole lofts questions, sound nervous and rich
Can you put contact data with the companythe grey ghost wrote:If your dead set on getting a stronger set, there is a company in Minnesota that will cryo/harden anything you want, I would suggest breaking them in first, so it shifts a little easier, or call the company that builds the terminator with intent to buy and ask a whole lofts questions, sound nervous and rich
Sorry I meant Wisconsin, there's one in Milwaukee and one in Waukesha/Treat All Metals, Inc. - Milwaukee, WI
Custom Manufacturer, Service Company
ISO 9001:2008 certified. Cryogenic treatment, deep freezing & sub zero stabilizing services. Capabilities include hardening, gas carburizing, carbonitriding, nitriding, quenching, normalizing, annealing, straightening, shot blasting, stress relieving, sub zero treatment & inspection. Suitable for various industries including automotive, defense, industrial, marine, mining, paper, plastic, racing, wind power & transportation. On-time delivery.
Therm-Tech of Waukesha, Inc. - Waukesha, WI
AS 9100:2009 and ISO 9001:2008 certified. Cryogenic services capable of cooling parts down to -300 degrees F. Capabilities include heat treating annealing, stress relieving, blasting, hardening, austempering, straightening, nitriding, quenching, carburizing, carbonitriding, normalizing and mechanical testing. Aerospace, agriculture, mining, heavy truck, oil field, railroad and tool and die industries served.
www.thermtech.net/machined-parts-stamping/c...
Here's another, there are more all over the state's /Controlled Thermal Processing, Inc.
PO Box 4005
Antioch, IL 60002
847 651 5511
PO Box 4005
Antioch, IL 60002
847 651 5511
Its technically not hardening exactly but a way to strengthen the crystaline structure of the metal, I'm saving my pennies, supposedly all the endurance racers are doing this deep cryo treatment
so your wanting to run a stroker motor with a manual transmission. why don't you get a stronger transmission and build it before you install it? just a thought.
Are there any stronger manual transmissions for the 4.0 that can be built up? If so I wanna know
