how fast is your 6
Off topic, play nice. No Nudity, Pornographic material etc..
turbojeeper
Vehicle Year: 1989
Vehicle Model: comanche
how fast is your 6
Post by turbojeeper »
Searched and didnt find anything. So I want to keep this simple. List your model. Engine and mods and 1/4 or 1/8 mile times and mph.
Me:
89 Comanche
4.0l turbo 6psi
1/4 - 14.6
1/8 - 10.07 @ 70 mph
boosted Comanche on megasquirt, 8.90"s in the 1/8th. getting faster one step at a time!!
turbostroker
Vehicle Year: 1991
Re: how fast is your 6
Post by turbostroker »
Jeep Wrangler 91
4.6l twinturbo 10 psi
1/4 - haven't run
1/8 - 9.06 @ 83.6 mph
Haven't finished a run on max boost yet (the engine is build for a max boost at 17 psi) because of 2 breakdown on the powertrain at max boost.
A stronger powertrain is under construction.
Jeep Wrangler -91 Twinturbo 4.6 Stroker
Bo Wernersson
turbojeeper
Vehicle Year: 1989
Since I can't find an edit button ill change it here. Just went a
9.55@ 72 mph in the 1/8
And did I mention the motor has 300k miles on it!
SIXPAK
Consistent
Consistent
Stroker Displacement: 280
Post by SIXPAK »
11.16 in the 1/4@117ish, 7.04 in the 1/8th@97ish cant remember exactly. N/A stroker, 2500lb jeep
vashxj
Vehicle Year: 1999
Vehicle Model: cherokee
Post by vashxj »
99 cherokee 4.0 with cai, open exhaust 205000mi
1/8- 10.04
1/4- 15.7
hoping for 13's with the new setup
turbojeeper
Vehicle Year: 1989
Really..... No one else? 4 of us. Thee has to be more that has gone to the track.
vashxj
Vehicle Year: 1999
Post by vashxj »
SIXPAK wrote:11.16 in the 1/4@117ish, 7.04 in the 1/8th@97ish cant remember exactly. N/A stroker, 2500lb jeep
thats insane what compression are you running
SIXPAK
Consistent
Consistent
Post by SIXPAK »
14.4 at that time
vashxj
Vehicle Year: 1999
Post by vashxj »
very nice i am hoping to touch 12s even if i have to shoot some n2o, but a 2wd swap with a supra valve body should help alittle
turbojeeper
Vehicle Year: 1989
Well new update again. Boost up to 9psi went
8.96 in the 8th. Dont know mph
racing89
Stroker Displacement: 306 ci
Post by racing89 »
4.00 in a 200' sand drag
mountaineerjeff
Stroker Displacement: 4.0
Vehicle Year: 1999
Post by mountaineerjeff »
60---1.8536
330--5.4892
1/8--8.5451
mph-80.23
1000-11.2077
mph-91.46
1/4--13.4737
mph-99.54
running with a ton of issues, including interference from ecm BC of no TCM, no O2, terrible tune running 10.3ish afrs, old all seasons, cracked header, low stall, and still getting used to the track.
hoping to go out on tues and make a cleaner run. really hoping to drop some time, but the DA really effects these boxes.
build thread http://www.cherokeeforum.com/f46/offici ... ep-179516/
N/A 14.9@89
N2O 12.7@104
TurboTom
Post by TurboTom »
Mine went OK.
1979 AMC Spirit
Building a Turbo 2.5
I am not very smart!
Desertjr
Post by Desertjr »
I'd like to run mine at irwindale or whatever strip is close to me. 4wd full time 5 speed is fun to drive. Wen my motors actually broken in & done ill do it.
I'd like to eventually run a 50 or 75 shot through it.
heavy equipment
I think I'll order a "tab"
Post by heavy equipment »
Driving my 4.7L '90 Cherokee with Borla header, I took my first long trip this month. I went from near Tucson to upper-mid Idaho and back, about 2400 miles. On the way back I decided to time 5 to 60 mph. Going up a freeway on-ramp pulling a 13' travel trailer (3000+ pounds) and camping gear, I clocked 20 seconds twice (on different ramps). The engine ran flawlessly all the way, averaging 14 mpg. That's the same as the previous 4L, but it was much faster up long, steep grades. Only trouble I had was back down in the Arizona desert: After stopping at a rest stop for 20-30 minutes it wouldn't start and keep running. Having experienced this before with the old engine I recognized vapor lock. It occurs when the gasoline gets so hot that the pressure drop at the pump inlet causes it to vaporize. Since the pump won't pump vapor very well, no start. I added 5 gal of cooler gas and got going. Researching, the best suggestion I saw was to add a quart or so of Diesel. Should work, but I haven't tried it yet. Next long trip, I'll carry a gallon of Diesel and see what happens...
Users browsing this forum: No registered users and 52 guests
