FlyinRyan wrote:Offtopic....Are you a controller?
No, Athletic Trainer, Certified
I thought that WOT was 'open loop' and the MAP wasn't involved?W_A_Watson_II wrote:The MAP Adjuster, is to allow you to fine tune the full throttle A/F ration right?
Nope. It's when the engine computer is in open loop mode that the MAP adjuster is effective. When it's in closed loop, the effect of the MAP adjuster is negated by the O2 sensor inputs.Retlaw01XJ wrote:I thought that WOT was 'open loop' and the MAP wasn't involved?
Thanks for the clarification!Cheromaniac wrote:Nope. It's when the engine computer is in open loop mode that the MAP adjuster is effective. When it's in closed loop, the effect of the MAP adjuster is negated by the O2 sensor inputs.Retlaw01XJ wrote:I thought that WOT was 'open loop' and the MAP wasn't involved?
If you ran WOT at 14.7:1 for any extended period of time you will be pulling the head off to replace the tulip-ed valves. Example, pulling a load up a hill.karl4x4 wrote:That is correct. It would only affect WOT. So, in real life, how often does one go WOT? But if I did, it could use to run slightly richer for cooling of the combustion area and also Fuel burn speed
this WOT is kind of funny. WOT (open loop) just kicks in the very last bit of throttle. so if one is to back up food 1/4 inch, it goes back into closed loop. so, extended period at full throttle -1/4 of a inch is bad?....?????SilverXJ wrote:If you ran WOT at 14.7:1 for any extended period of time you will be pulling the head off to replace the tulip-ed valves. Example, pulling a load up a hill.karl4x4 wrote:That is correct. It would only affect WOT. So, in real life, how often does one go WOT? But if I did, it could use to run slightly richer for cooling of the combustion area and also Fuel burn speed
