its been a while (getting the engine today after a year at the machine shop) but need to ask about injectors. I thought I had a set of ford 24lb injectors but that deal fell through. I have a 2000 intake I am going to put on and it came with injectors. I know the stock 91 injectors are not going to work. So, do I find another set of the ford 24lb injectors or can I use the stock 2000 injectors (slim and blue)?? I have and plan on using a Masters E2182 external fuel pump, (http://www.autozone.com/autozone/parts/ ... fier=56481) need to get a fuel pressure regulator from Leigh machine though.
thanks for any thoughts
injector for 4.6
Zorm
- Vehicle Year: 1983
Re: injector for 4.6
Try Ebay if you haven't already.Zorm wrote:So, do I find another set of the ford 24lb injectors
- Muad'Dib
Im still selling the basically new 23lb hr injectors that i used on my stroker.
http://www.jeepstrokers.com/forum/viewt ... =16&t=3646
Zorm
Muad'Dib, why did you take them off your stroker?
Zorm
ok, too big for your stroker, but you have a 4.7 right? then would these be too big for my 4.6?
- Muad'Dib
Every Stroker is different. Most everyone uses 23-24# injectors and they don't have any problems.
My Stroker for some reason doesn't want injectors that large. It wants an injector that flows 19.2lbhr @ 3bar... Dont ask me how or why... but its the sweet spot for MY Stroker.
Zorm
Ok so, I have three sets of injectors. The stock 91 ones (came with the 4.0), the stock 2000 ones (came with the intake and fuel rail), and some ford 24lb ones I picked up. Which ones to use, I know the stock 91 ones are out of the questio , what about the stock 2000 ones? or stick with the ford ones?
