im getting frusterated trying to look thru this info on this stroker stuff. and not finding the info i need really. i need budget, and asap. i can do all work at shop i work at.
i have a 4.0 sittin here. cylinders are GREAT other than the rings are siezed to the cylinders. but there is no lip or anything. the motor in "honey badger" ('82 sx4) has #5 hole dieing more and more every 5000 miles i put on it. when i put the 4.0 head on, i couldnt beleive the bores. i have never seen a motor with so much wear and it still runs. just wontering if i could get a set of bearings for a '93 (year of my 4.0 block.) and toss in my '79 4.2 crank. im hoping to just bust the rings loose and be ok. if it will run, it wont be any worse than my 4.2 is now. this 4.0 came out of an auto jeep cherokee. will my flywheel from my 4.2 in my '82 car work with the '79 4.2 crank bolted to the '93 4.0 rods/pistons? and what about front ballancer and drive system? i want to use my 4.2 v-belt ballancer, and all v-belt drive system. can i do this? o and i noticed tonight that the 4.0 has a reverse rotaion water pump it appears. will my BRAND NEW 4.2 standard rotation water pump work on the 4.0 block?
i know, lots of questions. i need a motor that runs better than this wheesing 5.5 cyl thing im running now.
will this work?
casper
- Vehicle Year: 1982
- Vehicle Make: amc eagle
- Vehicle Model: sx4
will this work?
'62 rambler classic custom 2 door (casper
'82 eagle sx4 (honey badger)
'79 spirit (drag car)
life aint about just ridin along. its about goin out with 4 tires screamin, cloud of smoke, screamin "HELL YA WHAT A RIDE!!!"
Re: will this work?
No. The 4.0L rods will put the piston about 1/4" above the deck. You can use stock or aftermarket stock style 4.0L pistons on the 4.2L rods with the 4.2L rods. If you want to use the 4.0L rods you need either the Keith Black Icon forged pistons, Bulltear forged pistons or some other custom pistons.casper wrote: just wontering if i could get a set of bearings for a '93 (year of my 4.0 block.) and toss in my '79 4.2 crank.
doubtful, but not unheard of.im hoping to just bust the rings loose and be ok.
Don't know about the rest of the accessories, but the balance will bolt up as you are using the 4.2L crankand what about front ballancer and drive system? i want to use my 4.2 v-belt ballancer, and all v-belt drive system.
casper
Re: will this work?
so im going to have to pull the pistons out and put them on my '79 4.2L rods also then? ok, no problem. got a press, and a rod heater whatcha macallit for putting pins in.
Re: will this work?
pretty much. If you can press the pistons off with out damaging or distorting them.
str8-6
- Vehicle Year: 2012
- Vehicle Make: Hot Rod
- Vehicle Model: T-27
Re: will this work?
I'm using the balancer and waterpump from a -73 258 on my engine, works as it should,no problems "that I know of..."
Users browsing this forum: Amazon [Bot] and 8 guests
