I was interested in this one:
http://www.summitracing.com/parts/AVM-30-4100/
Have any one tried it ??
Thanks Silver,SilverXJ wrote:The AEM and tuning is useless without a wideband O2 gauge. You need to see the AFR to see what the engine is doing to make changes. How are you doing that now with the AEM? If you keep pushing the engine when it is having problems after 3000 rpm w/o knowing what it is doing you may damage the engine.
As for cooling, try putting the stock pump back in.
Most of them yes...ossme wrote: So, Can we now eliminate any fuel pressure problems ??
Thank you for taking some of your time to look at my truck in this blazing heat. others would of simply preferred watching TV with a nice icy drink instead!Cheromaniac wrote:Hi Osama,
Thanks for driving all the way from Abu Dhabi to my place last Friday so I could take a look at your truck. My observations are:
Unfortunately, this is very true. I was under the impression that he was a reputable tuner. I should of known better not to entrust any one from Mussfah on my truck.Cheromaniac wrote: 1. The tuner has f***ed up your AEM tune big time and whoever did the wiring for your PCM deserves to be shot. With the AEM tune the engine runs like shit at higher rpm, takes more cranking to start, and bogs down off-idle when you blip the throttle.
True, It rives better and pulls stronger without the AEM crap.Cheromaniac wrote:2. Your engine starts and runs much better with the stock PCM tune but the only snag is that it pings when it gets over 220*F even with premium fuel plus octane booster.
So, should I stop worrying about it or should investigate it more ?Cheromaniac wrote: 3. Golen must have used CompCams valve springs as well as the CompCams 68-235-4 cam in their stroker 'cause it clatters like a tractor engine at idle. Good thing the clatter disappears when you drive off and the hot oil pressures are good.
Thank god, at least I have something to strike out of my list !Cheromaniac wrote: 4. There's nothing wrong with your cooling system and swapping/changing parts won't help anything.
Hopefully, We will find out soon enough. Almost all of the AFR gauge items are here. I just need to buy some little stuff and wiring from the local shops..Cheromaniac wrote: 5. The reason why your engine's pinging is because it's running too hot. My guess is that the engine's running lean at low rpm with the stock PCM tune since that's where the ping occurs (around 1500-2000rpm). This isn't helped by the fact that we've been having ambient temps. of 110+*F. I forgot to ask you what spark plugs you're using but you could try a set of colder plugs like the Champion RC9LYC.
I will finish the AFR first and then I will look into this.Cheromaniac wrote: 6. Your winch is blocking half of the radiator airflow but you said the engine still ran hot even without the winch. Try removing it and see.
So, I don't need to do a WOT Test ?Cheromaniac wrote: 7. The 49psi fuel pressure is right on the money and the low rpm ping won't be due to a bad fuel pump or a clogged fuel filter, but you could try changing the latter anyway if it's old.
I got it with the car and I don't have the original.Cheromaniac wrote: 8. Your cold air intake is actually a hot air intake with the filter sucking in hot underhood air (might be 180+*F at this time of year) because the "heatshield" that came with your CAI is useless. If you still have the stock air intake assembly as a spare, try swapping it back in. The ambient air that it'll inhale will still be hot (110+*F) but that's a lot better than having the engine inhale air that's at 180+*F.
Thanks, I will look into that ..Cheromaniac wrote: 9. Insulating the underside of the intake manifold with a Thermotec heat blanket (like I did) will block most of the radiant heat from the header and keep the manifold cooler.
Thanks !Cheromaniac wrote: 10. Your hood vents look great and are positioned exactly in the right place near the front of the hood.
I had plenty of time to do that after you left.ossme wrote:Thank you for taking some of your time to look at my truck in this blazing heat. others would of simply preferred watching TV with a nice icy drink instead!
Since your valvetrain has been noisy from the outset and the sound hasn't changed, I don't think you need to worry about it. Your ears have probably got used to it by now.ossme wrote:So, should I stop worrying about it or should investigate it more ?![]()
Those Champions are the same heat range as the ones I'd already suggested so leave them in.ossme wrote:Regarding the spark plugs, I'm Currently using Champion RC9YC4 and I was using Mopar ones before.
It's better if you do that anyway so we'll know for sure if your engine's starving for fuel at high rpm.ossme wrote:So, I don't need to do a WOT Test ?
No, don't waste your money on another cold air intake. Just improve the heatshield you have on your existing CAI.ossme wrote:I'm think about Spectra Performance Cold Air Intake.
http://www.quadratec.com/products/17006_7000_07.htm
Do you think that it is a good idea ??
Users browsing this forum: Amazon [Bot], HeckIV, Semrush [Bot] and 4 guests
