stroker motor build
yj-woody
Vehicle Year: 1993
Vehicle Model: yj
stroker motor build
Post by yj-woody »
I am building a stroker motor right now. 93 yj 4.0 block. Bored out 30 over.4.2 crank.4.2 rods. What I am looking for is my head springs are stock. So what cam do I use? Or can I use the stock one? And later next winter or when ever change head springs and cam out? Its going in a 93 yj 5speed. 8.8 locked. 33in tires 4.10 gears full body armor. And flat tube fenders. I am running a cold air intake. 2.25 exhaust with a flowmaster muffler. All said about this motor build would it be the 4.6 or 4.7. Thanks guys..
Re: stroker motor build
If you want to keep the engine simple and reliable, just use the stock cam with stock springs as I did. Your engine will displace 4587cc so it'll be a 4.6.
yj-woody
Vehicle Year: 1993
Vehicle Model: yj
Post by yj-woody »
Ok found out my lifters and cam is not in the best shape. So in need of a cam and lifters. What cam will work with stock springed head? Thanks guys. I have looked but don't want to blow something apart.
There are a few cams on my spreadsheet at http://www.angelfire.com/my/fan/Jeep4.0Camshafts.htm with a valve lift of 0.45" or less and I suggest you go for the Crower 44243.
Retlaw01XJ
Vehicle Year: 2001
Post by Retlaw01XJ »
Cheromaniac wrote: I suggest you go for the Crower 44243.
That's the one I chose. With the stock springs it revs nicely to the 5000 rpm shift point.
It's a tad more cam than stock, which I felt was a nice match to the extra cubes of the 4.6.
I can't offer any before/after driving impressions, as I barely drove my Jeep before the rebuild (just on and off the trailer!)
Walt K
Eastern Pa
yj-woody
Vehicle Year: 1993
Vehicle Model: yj
Post by yj-woody »
Thanks guys i am going to check out that cam..
RayRay
Vehicle Year: 2002
Post by RayRay »
if you are looking for a great offroad cam to go in that id go for:
comp.68-232-4 extreme off road .460in.-.476ex.
it most definiately pumps up the power and has a very smooth but ready to pounce idle.
RayRay wrote:if you are looking for a great offroad cam to go in that id go for:
Agree. It does have those qualities but with that much valve lift you can't use the stock valve springs.
yj-woody
Vehicle Year: 1993
Vehicle Model: yj
Post by yj-woody »
I have my motor almost built. And a guy just told me that i need a differnt computer to run this motor.. I haven't read anything about that. Is this true? Its going in a 93 yj. With a 5 speed trans. Thanks guys.. I did go with a stock cam. But new. Every cam i was looking to get was on back order. So stock it was..
yj-woody
Vehicle Year: 1993
Vehicle Model: yj
Post by yj-woody »
Anybody know? Thanks
604rail_king
Vehicle Year: 1995
Post by 604rail_king »
Untrue. Stock PCM is fine however you could add a map adjuster or piggy back controller to tune your WOT a/f's if you wanted to
Your stock computer will be fine. I do recommend larger injectors. You can control the open loop AFR with a MAP sensor adjuster or a fuel pressure regulator.
yj-woody
Vehicle Year: 1993
Vehicle Model: yj
Post by yj-woody »
Thank you guys. I am putting in the ford injectors. What should the fuel pressure be set at? If i get a regulator..
604rail_king
Vehicle Year: 1995
no need for an adj fpr with the larger ford 24# injectors.
yj-woody wrote:Thank you guys. I am putting in the ford injectors. What should the fuel pressure be set at? If i get a regulator..
I'm running the stock computer, stock FPR, and Ford 24lb injectors but with my homebrew MAP adjuster set slightly higher than stock at 5.3v. The engine pulls like a freight train all the way from 800-5200rpm with no bucking or hesitation and driveability is excellent.
