Rear main seal sealant?
- EVIL95XJ
- Vehicle Year: 1995
FSM calls for loctite 518. None of the parts stores around me carry loctite brand. What is best to use?
Ford 24# injectors - PM me
5-90
Re: Rear main seal sealant?
On which bit?
I've always used the later (1996-up) one-piece moulded gasket (dry) and dropped the new RMS in clean engine oil before I started tearing things down - let it soak until you install it.
FSM says to put a touch of RTV on the ends of the seal, but I've not bothered - that's why I soak it.
Haven't had any trouble, just don't install the seal backwards.
- EVIL95XJ
FSM calls for a anaerobic sealant, loctite 518 which i found in permatex brand part number 518135-90 wrote:On which bit?
5-90
I know - where does it say to use it? That's the part I don't recall (often, the two-piece moulded rear mains want it between the ends of the seal halves. The old "rope" seals just get trimmed and run.)EVIL95XJ wrote:FSM calls for a anaerobic sealant, loctite 518 which i found in permatex brand part number 518135-90 wrote:On which bit?
I don't like to do it, because I don't know if it's going to get into anything or not. Even if you use just a pinpoint, you can't quite be sure where it's going to end up (but it usually stays put.)
Ergo, I modified the procedure slightly. I've done it the way I've described a number of times now, on different vehicles, with no ill effect.
Although, LocTite #518 Gasket Eliminator is good stuff - it's saved me on jobs where I couldn't find the gasket I needed (I used to be an industrial mechanic, and usually ended up working on equipment older than I am.)
- amcinstaller
- Vehicle Year: 1980
- Vehicle Make: AMC
- Vehicle Model: Spirit
taking a stab at it, i think i remember reading mitchell ondemand saying to put a dab or two where the two halves meet on the main cap. but when i did mine, i didnt bother either, just soaked it and installed it. never had an issue
This may help: http://www.go.jeep-xj.info/HowtoRearMain.htm
- EVIL95XJ
perfectSilverXJ wrote:This may help: http://www.go.jeep-xj.info/HowtoRearMain.htm
Users browsing this forum: Amazon [Bot] and 7 guests
