computers!!
- amcinstaller
- Vehicle Year: 1980
- Vehicle Make: AMC
- Vehicle Model: Spirit
computers!!
hey all, great site!! im building a stroker right now, 92 4.0 block, 258 12cw crank and rods, .040 dished pistons. thats all i have for now, but im lookin into cams, head stuff, so on. my biggest question right now is, what computer should i use?! ive been looking at megasquirt alot lately, and ive been told alot about it, even my machinist referred it to me. we also looked at a couple other ideas, but i dont really know. what computers or computer modification combos have been tried, what works, what doesnt?
- John
Re: computers!!
I like the OBDI Jeep factory computers, but I am also considering a custom Unichip from Hesco to improve a couple of areas.
Re: computers!!
the problem with the ODBI computers is that they are not re-programmable and thus will always be off the trim for perfect AFR calculations. Also replacing the injectors with something else will confuse it as it's hard programmed for the stock injectors. Upon start up when the O2 sensor hasn't warmed, you can run into really lean conditions. If you're looking for a good solution look for OBDII at least or something you can set different CAL values for.
- John
Re: computers!!
Do tell how you are so effectively reprogramming Jeep OBDII computers.
Re: computers!!
by definition ODBII controllers are reflashable, I don't have one so I haven't investigated the matter any but I have heard of them being reflashed and recalibrated
- amcinstaller
- Vehicle Make: AMC
Re: computers!!
i heard once that a US company called jet (i think??) would reflash your computer for you. well, maybe it wasnt in the states. i forget where, but thats the company that could do it, if you sent them yours with their fee.
Re: computers!!
Here ya go:
Hello,
The OBDII ECUs for the 4.0 can be reprogrammed, but the OBDI units are not flashable unfortunately.
If you need any programming work done to your OBDII ECUs, please let me know.
Thanks,
Nick Ianuzzi <-Kolak
Kolak Performance and Offroad
A Division of: Multitronics, LLC
Member: Specialty Equipment Market Association
Telephone: 480 998-3661
Hello,
Thanks,
- amcinstaller
- Vehicle Make: AMC
Re: computers!!
how much? how accurate? what kind of turnaround time? i guess id just like a little more information. this is maybe alot cheaper than the 2500 engine management system ive been looking at.
Re: computers!!
I didn't know that you can reprogram the OBD II computers. However, I have done business with Nick in the past and he hasn't let me down.
Re: computers!!
I have been running the Unichip piggy back computer from Hesco for two years now. No performance gains that I could feel by the seat of my pants. Gas milage improved alot. No problems to speak of. I called the guy's at Unichip and asked if I should have it programmed on a dyno. They said it wouldn't be worth the money, not much if anything could be gained. I am running the Ford 24 Lb/hr fuel injectors.
Mike
Mike
- amcinstaller
- Vehicle Make: AMC
Re: computers!!
does anyone know which megasquirt version we would need to megasquirt a stroker?? which sensors would be needed to make it work right? ie. factory flywheel from Renix, OBDI or OBDII?
- Vehicle Model: mj
Re: computers!!
I would like to see more on the different options here. My 92 4.6 is looking for something between 2900 -3100, feels rich to me, but after a second it really takes off. Any one want to help an old fart figure out which type upgrade to use. I'd like to be able to see what's happening in there.
Re: computers!!
I sent my PCM off to Nick Ianuzzi (Kolak) will let you know the results when I get it back. It is a custom tune and I sent him all my engine's details.
Re: computers!!
What year vehical?...OBDI or OBDIISilverXJ wrote:I sent my PCM off to Nick Ianuzzi (Kolak) will let you know the results when I get it back. It is a custom tune and I sent him all my engine's details.
- amcinstaller
- Vehicle Make: AMC
Re: computers!!
yes, id like to know all that too. year, engine system, which year of sensors, turnaround time, price, how far away (shipping time would be different for different locations). sorry to ask so much, but i really want to figure out which would work the best for me.
Users browsing this forum: No registered users and 38 guests
