Cylinder head
FARMER
- Vehicle Year: 1995
- Vehicle Model: ZJ
Cylinder head
I've done the search thing and am unable to find an answer to a question I have. I'm bulding a long rod 4.6 low buck stroker. The question is: will a stock head work or do I need to have to go with a roller valve setup?
Re: Cylinder head
Stock will work fine.
Re: Cylinder head
Not sure what you mean by "roller valve setup" but I guess you're referring to roller rocker arms.FARMER wrote:I've done the search thing and am unable to find an answer to a question I have. I'm bulding a long rod 4.6 low buck stroker. The question is: will a stock head work or do I need to have to go with a roller valve setup?
You can use the stock head with stock stamped steel rockers.
- IH 392
Re: Cylinder head
FARMER wrote: I'm bulding a long rod 4.6 low buck stroker.
dragginwagon406
Re: Cylinder head
I used stock head, cam and lifters with my long rod 4.6L. I would have liked to have ported the head but did not due to time constraints.
I do notice top end falls off past 4200 rpm but low end torque is pretty much amazing.
Re: Cylinder head
There is now if you look at my stroker recipes.IH 392 wrote:FARMER wrote: I'm bulding a long rod 4.6 low buck stroker.no such thing, those use expensive pistons.
A set of Keith Black IC944 pistons costs $416 so that's not much more than the cost of a set of 677CP pistons ($140) plus a set of reconditioned 4.2 rods (average $200 in ebay). Therefore the only reason left for using 4.2 rods in a stroker build these days is if you want to build a close copy of my "low CR rockcrawler" recipe.
FARMER
- Vehicle Model: ZJ
Re: Cylinder head
Thanks guys, I figured I could use the stock head I just wanted to verify.
- IH 392
Re: Cylinder head
It's about $120 for recon rods if you use the ones that came in the 258 core engine you use for your stroker.Cheromaniac wrote:a set of reconditioned 4.2 rods (average $200 in ebay).
- amcinstaller
- Vehicle Year: 1980
- Vehicle Make: AMC
- Vehicle Model: Spirit
Re: Cylinder head
or less if you happen to have an old 258 laying around cause your amc or jeep came with one
Re: Cylinder head
That's true but then the 258 crank would also cost a lot less.amcinstaller wrote:or less if you happen to have an old 258 laying around cause your amc or jeep came with one
- IH 392
Re: Cylinder head
Well my '75 12cw crank engine was put on the back of my flatbed when I wasn't looking! can't get much cheaper than that!
and I sold the rods to Muad'Dib for $40 and he paid just shy of the $120 I posted for the recon of them, so that's about the going rate for a full recon of a set of rods, but if you think your rods are ok to run it could be a lot cheaper.
- amcinstaller
- Vehicle Make: AMC
Re: Cylinder head
got my 80 12 cwt the same place as my short rods. wailed a porcupine at 140kmh, popped my oil filter (it was larger for more filter capacity) and the rest is history. cleaned up to 10/10 tho, cant compain.
Re: Cylinder head
good one
- amcinstaller
- Vehicle Make: AMC
Re: Cylinder head
yea, not a bright moment for me
Users browsing this forum: Bing [Bot] and 8 guests
