Spliffotticle wrote:However I hate to be the piss in your cheerios but as I stated I have already VERIFIED that the CMP CLEARLY affects spark timing and you can verify this too by taking a wire from your #1 plug top to another spark plug grounded, attatch a timing light, and adjust the CMP and the SPARK timing will change irradically.
While it may effect spark as well as the injectors It only has one correct installation/indexing position.
Also, are either of you running an advanced cam with a CMP instead of a dizzy? Because that would be killer and I would have some hard evidence.
My cam is advanced 4* and no issue with injectors or timing. As I said before spark advance and retard is based on the crank/piston position, not on the cam position. For example "14* before Top Dead Center". That is on the piston position relative to the top of the cylinder, not to a cam lobe positions. That 14* is also crank degrees.
Ideally I would prefer to fix this.
As 4.whoa said, that is where your problem most likely is. The PCM uses the TPS information a lot. A faulty TPS will give the exact symptoms you describe. Sounds like you have a real mess there.
