Melling oil pump doesnt fit
Biggrnjeep97
Post by Biggrnjeep97 »
Has anyone tried installing an m81-A Melling HV oil pump and find it NOT fit under the the stock oil pan. 96 block and 97 pan. Searching yields no other finds. Theres probably ~.25" interference. :doh:
*edit* - Ma bad, the part number that doesnt fit is M167HVS.
Busey
Vehicle Model: TJ
Re: Melling oil pump doesnt fit
Post by Busey »
That is normal with the high volumn pump. look in the project section , most guys clearance the pan with a hammer
Biggrnjeep97
Busey wrote:That is normal with the high volumn pump. look in the project section , most guys clearance the pan with a hammer
Feeling like a dumbass. Thanks for pointing it out. Sudo Chops got good info on his first page. Will post pics of the pan later.
lafrad
Post by lafrad »
I actually removed part of the baffle on my '99 pan... saved me from having to REALLY wail on the pan and only just nudge it a bit with the 3 lb sledge.
YJason
Post by YJason »
I just removed my Melling HV oil pump, it ate my distributor gear and cam. I talked to Hesco and they told that HV oil pumps on a jeep 6 cyl will eat dist gears, I learned the hard and expensive way. ********Results may vary*********
If your bearing clearances are correct you don't need a HV oil pump. :deadhorse:
Users browsing this forum: Semrush [Bot] and 20 guests
