Max spring pocket/seat cut depth?
Whats the max amount anyone has cut out of the spring pocket/seat or the usual amount? I know that you need to cut for Hesco's springs but I don't have a figure on how much needs to be cut out.
Re: Max spring pocket/seat cut depth?
Post by dwg86 »
Are you going to run a different spring?
shawnxj
I love this board
I love this board
Vehicle Model: cherokee
Post by shawnxj »
i'm going to run the lunati springs and according to the tech guys i shouldn't have to cut the pockets at all. i'll know for sure in the next couple weeks
SIXPAK
Consistent
Consistent
Stroker Displacement: 280
Post by SIXPAK »
.125" EASILY, I have cut some as much as .250"
Its for spring locators. Only .060" thick
Post by dwg86 »
What are the spring specs? Will they work with the stock retainers?
SIXPAK
Consistent
Consistent
Post by SIXPAK »
SilverXJ wrote:Its for spring locators. Only .060" thick
Cut away you will be fine sir!
dwg86 wrote:What are the spring specs? Will they work with the stock retainers?
Who are you asking?
That is what I thought. Just wanted to verify before something bad happened.
Post by dwg86 »
Who are you asking?
I'm asking SilverXJ.
It would be nice to have an alternative spring to use.
They are just the Mopar performance that I have been using.
djergensen
Vehicle Year: 1994
Post by djergensen »
Did you decide to cut the spring pockets? I also have the lunati springs/cam and they are coming in a bit to much pressure 135# at 1.65 - so he suggested .125 but in not sure the depth - before hitting the water jacket. .125 will work?
Users browsing this forum: Bing [Bot] and 36 guests
