Cam selection.. isky.. engle... lunati
After my Comp Cam failed I think I want to look at other avenues, as I have had a bad lifter from Comp previously as well. I'm looking at the Lunati 63501, the Isky 133125/26, and possibly a Engle cam, but haven't heard back from them for a grind recommendation.
Also Isky recommended me this custom grind:
.464 intake lift
.480 exhaust lift
adv duration: 258 intake, 264 exhaust
duration at .050": 208 intake, 214 exhaust
112 lobe center
Seat:Open Close
Int 20 58
ex 67 17
.050:open close
int 5 33
ex 42 8
1800-5800 range
I liked the performance of the Comp, but would like a little better idle quality (although the idle was nothing to bitch about), and a quieter valve train. This is on my daily driver.
Opinions?
crustodd
Stroker Displacement: 284
Vehicle Year: 1994
Re: Cam selection.. isky.. engle... lunati
Post by crustodd »
Hey,
I have the Lunati in your list and I like it. It's a bit noisy at times what with the RR' and the profile snapping the valves shut so quick. Nice power band though.
T~
Post by dwg86 »
You can also try Racer Brown. I talked with Jim on the phone. Great guy. I was only buying a set of Stanadyne lifters from him, but he talked for at least 20 mins. He said he could grind a Jeep 6 cam. his web site and phone number...http://www.4secondsflat.com/RB%20Cam%20Specs.htm
Hughes engines also grindes Chrysler "real" cams for the .904 dia. lifter. They also can grind a Jeep 6 cam. http://www.hughesengines.com/TechArticl ... lercam.php
I think Reed cams went out of business. Thier web site is down and phones have been disconnected.
I bought an Engle cam. 213 dur @ .050, 501 lift, 112 lobe centers, for my stroker. I still haven't installed my engine yet, so I don't know how it will perform, or last.
I bought a 97 dakota for my son, he will be 16 in Oct. As soon as I get it on the road, I am going to swap my Jeep engine out. That way I will have something to drive while my Jeep is down.
My personal opinion is stay away from mass produced cams from the "big" companies. I have a Reed cam in my 401 that was broken in without ZDDP, I didn't know about that at the time, and it is running great.
dwg86 wrote:You can also try Racer Brown. I talked with Jim on the phone. Great guy. I was only buying a set of Stanadyne lifters from him, but he talked for at least 20 mins. He said he could grind a Jeep 6 cam. his web site and phone number...http://www.4secondsflat.com/RB%20Cam%20Specs.htm
So many options.. this is why I went with a Comp Cam to begin with... and the fact that I used them in the past with good results...
When you say real cams, are you talking about the wider lobes?
Post by dwg86 »
Hughes engines calls thier cams "real Chrysler cams". From what I've read on thier web site, the cams are designed to use a fast ramp that can only be used on the larger .904 lifters. The smaller diameter lifters, like sbc, can't use a fast opening ramp. The Hughes cam specs look like the same specs as Engle.
Flash
Post by Flash »
When I buy my next cam, i will do some investigation with Racer Brown. Every net site i have ever been on and the the word "Racer Brown" comes up, It's alway good.......Inexpencive was never one of the word used. But if your after a "custom" grind, it never will be ;)
I recieved a reply from Engle Cams today. This is what they recommend:
EP-22HYD .512" lift 274' duration 230' dur @ .050" 110' lobe centers Power band 1800-5800 RPM $232
I'm no expert on reading a cam so I run them through Desktop Dyno. While I feel it doesn't give a good absolute hp and tq measurement it makes for a good comparison.
That showed a significant drop in torque and HP until 4000, where most of the cams I am looking at crossed. After that the torque and HP rose significantly above the others. Don't think that is a cam I want.
Post by dwg86 »
230 dur @ .050 is not a torque cam. That is a fairly big cam. The cam in my 401 has 228 @ .050, 110 lobe centers. At idle it will shake the filling out of you teeth.
I would run a 52hyd (209 @ .050 /489 lift) or a 54hyd (214 @ .050 /501 lift) Or a combination of both (52hyd on the intake and a 54hyd on the exhaust) with 112 lobe centers. If you go to Engles web site,look under the cam specs for the amc v8.
Hughes Cams won't do an L6 cam
I've been playing around some numbers and came up with this:
intake lift: .465
exhaust lift: .480
adv duration: 250 intake, 264 exhaust
duration at .050": 205 intake, 214 exhaust
Intake centerline: 110
Exhaust centerline: 114
lobe center: 112
Seat timing:
Open Close
Int 15 55
ex 66 18
.050 timing:
open close
int -7.5 32.5
ex 41 -7
Thoughts on that?
The numbers look good and your power oughta start alot earlier than the cams you previously posted.
I took the numbers that Isky gave me for a custom and played with them a bit. Looked at the comp cam and determined that I didn't like the rate, so I reduced that and increased it a bit from the Isky. Increased the lobe center angle for better idle. According to Desktop Dyno, it will have a bit less lowend torque than teh Comp cam, but more HP and torque after 3500.. in theory anyhow.
Talked to Jim @ Racer Brown today. He suggested a cam with .460" lift, 210* @.050 duration and 110* LSA. He said that would perform well and have a fair idle. He also suggested a cam with .450" lift, 206* @.050" duration and 110* LSA which would have better idle quality, a bit less top end and faster ramp rates.. which would make a noisier valve train.
Now I just don't know... my head hurts..
What Jim recommended is basically what the mopar 30ab is, except the lsa is 108*, which works fine on my obd2--I like the slight lope. The isky that sean is using, the 133125/26 is similar as well, so talk to him about his impressions(he hasn't been saying much lately).
Which one of Jim's are you talking about? The first, larger one?
I did get in touch with Sean and he had this to say:
Offline and midrange torque are good, although I dont think it pulls too hard over 4k, but thats not where I spend most my driving so I think it suits me. I used the 133125/26 because it was dual pattern with larger exhaust lifts which helps offset smaller exhaust ports on the head. My head isnt ported but if it was I think it would wake things up more.
The custom cam the Isky recommended seems a bit better...
Jim was adamant about not going with a dual pattern.
The 2nd one w/ .45" lift is similar to the mopar. The isky 133125 looks like a good option. The custom isky above looks like it starts later than you should want and you wouldn't use the upper part of the range(better to have it down 500rpm). I haven't seen the lunati options yet.
edit: Man the lunati looks like a wicked cam:
* Advertised Duration (Int/Exh): 256/262
* Duration @ .050 (Int/Exh): 213/220
* Gross Valve Lift (Int/Exh): .484/.507
* LSA/ICL: 112/108
* Valve Lash (Int/Exh): Hyd/Hyd
* RPM Range: 1300-5400
* Includes: Cam Only
The 96+ jeeps came with dual pattern cams, so what's the big no-no about them?
