ATk's Stroker Idleing at 4000rpm's Help!
Russ_93yj
- Vehicle Year: 1993
Re: ATk's Stroker Idleing at 4000rpm's Help!
- 1bolt
Gradon gets the credit here, I didn't catch the Borla on 99+ until he pointed it out.
The Borla person in all likelihood just ran his finger down a matrix that said 93 YJ and gave you a part number. Even if you mentioned the intake from a 99 is very unlikely the guy would have either notes or experience with it, hell up to a year or two ago I didn't know a Borla long tube wouldn't fit with the 99+ without working the #5 primary and/or the intake.
Most people like most mechanics just assume things DON'T work between years, Jeepers are odd this way, myself included... We have all those common engine types and interchangable parts and we're used to seeing them mixed between models and years.
Simon
Simon
yuppiexj
Agreed. my 94 XJ has a 89 front axle (with the replaceable caliper mounts that bolt to the knuckles vs. cast into the knuckles), a 99 engine and an 88 transmission/95 transfer case.1bolt wrote:Most people like most mechanics just assume things DON'T work between years, Jeepers are odd this way, myself included... We have all those common engine types and interchangable parts and we're used to seeing them mixed between models and years.
When I buy parts I order by part number alone and don't let the trained counter monkey look anything up.
/end thread hijack.
I'm glad this was a relatively simple cause/fix.
Users browsing this forum: Ahrefs [Bot], Bing [Bot] and 6 guests
