WJ exhaust manifolds with 7120 head
- StroktWJ
- Vehicle Model: Grand Cher
I am hours away from dropping the 4.6L stroker into the WJ, I am running the 7120 head and I know the exhaust ports on the 7120 head are much larger. So large in fact that in order to run the WJ exhaust manifolds I need to use the 99+ steel exhaust gasket which blocks most of the port. I know for optimal performance this is not good, but I am just trying to get it running and drivable this weekend.
#727 Crank
Clevite 3415 Pistons
91-95 Camshaft
7120 Head
00 Intake
Magnaflow Muffler
Offroad Pipe
#727 Crank
91-95 Camshaft
7120 Head
00 Intake
Magnaflow Muffler
Offroad Pipe
- Muad'Dib
Re: WJ exhaust manifolds with 7120 head
Why not use a XJ exhaust manifold and have an exhaust shop (or yourself if you can weld) make it work? It shouldnt cost that much to tie it into the existing system...
- StroktWJ
ultimately that is what will happen in the end. I will just buy a stainless header and run a single exhaust but at this point I was just trying to fire it up this weekend and break her in.
#727 Crank
91-95 Camshaft
7120 Head
00 Intake
Magnaflow Muffler
Offroad Pipe
#727 Crank
91-95 Camshaft
7120 Head
00 Intake
Magnaflow Muffler
Offroad Pipe
Why do you need to use the 99+ steel exhaust gasket? I have heard that 99+ after market headers will work find on an earlier head.. don't know for sure though.
Users browsing this forum: Bing [Bot] and 6 guests
