Pilot Bushing/Bearing
Post by dwg86 »
Does anyone know if the piloit bearing for a 4.0 will fit in the 258 crank?
Re: Pilot Bushing/Bearing
From this thread: http://www.naxja.org/forum/showthread.php?p=375659
Dr. Dyno wrote:The 53009180AB pilot bearing will work with the AMC 258 crank & '92-'99 AX15, but it won't work with the '89-'91 AX15. You need pilot bearing 33004041 so the stealership was correct.
It appears that all 4.0L did not have the same bearing.
I used the pb77hd bushing from AA($3-5). It has a 1.06" OD and .75"ID.
Post by dwg86 »
What year Jeep? I have a 2003 TJ with NV 3550 trans.
Post by dwg86 »
I an trying to get all the correct parts for my engine swap. Hopefully in and out and running within a couple days. I don't have my engine out to look at. Does the pilot bushing go into the big diameter hole close to the trans, or the smaller hole further in the crank.
Post by dwg86 »
I bought a pilot bearing today from oriellys. Part number fc69907 $11.99 + tax. The dealer wanted $25.00. It's a big metal sleeve with a roller bearing pressed in it. I hope it's the correct bearing.
Stupid question.. you only need a pilot bearing for a manual, correct?
Post by dwg86 »
Correct.
Users browsing this forum: Google [Bot] and 33 guests
