Piston pin
Posted: April 14th, 2009, 5:18 pm
by laxplayermjd
Does anybody press their own rods and pistons at home? I would like to save as much money as possible when doing my first build. I have a way to heat the rod but as far as putting the pin in too far or not far enough is what im worried about.
Re: Piston pin
Posted: April 14th, 2009, 5:25 pm
by hatem61
I never did it but some claimed that freezing the pins in the fridge the night before helps with the fittment.
Re: Piston pin
Posted: April 14th, 2009, 6:50 pm
by Mgardiner1
Don't cheap out, have a machine shop do it. You'll be mad as hell if you squash a piston or damage it in any other way
Re: Piston pin
Posted: April 14th, 2009, 7:09 pm
by John
Mgardiner1 gave you some good advise. If you really are set on doing it yourself, this is how to do it.
http://www.fordmuscle.com/forums/all-fo ... ation.html
Re: Piston pin
Posted: April 14th, 2009, 7:56 pm
by laxplayermjd
About what would it cost for the machine shop to do it? What have you guys paid?
Re: Piston pin
Posted: April 14th, 2009, 8:02 pm
x2.. my machine shop only charged me $20 to put the pistons on the rods, but they also weighed each piston and rod prior to assembly so i would have to done it after they weighted it all any how. And i wasn't about to damage a $550 set of pistons trying to ham fist them in or cook a rod. This isn't the area to skimp and do it yourself.
Re: Piston pin
Posted: April 15th, 2009, 4:16 pm
by John
The local rate here is $15 to remove 6 pistons and the same to mount a set. That includes the weight matching at installation.
