2.25" Stroker Exhaust Manifold / Exhaust System Recommendations
Posted: January 28th, 2026, 5:24 pm
by etnlvn
Good Evening All,
I'm spanking new to the forum but really excited about drawing from the community's knowledge and experience. I own an '06 Jeep TJ Rubicon with a recent, and perhaps inevitable, cracked head. I've made a few decisions: first, my old 4.0 is out. I'm replacing with a stroker. I've also decided to go with S&J Engines out of Spokane Valley, WA. I'm going with their updated head as well as the COMP Cams Xtreme 4x4, Hydraulic Flat Tappet; 205 Int./213 Exh. at 0.050 in., 0.450 Int./0.450 Exh. Lift;113 Lobe Sep 205/213; Torque/Throttle Improve; (EFI w/OEM Head), and the COMP Cams High Energy Timing Set. I think I have all, or at least most, of the related questioned resolved except, for the exhaust system. I'm less concerned about sound than I am providing the right amount of airflow. It's easier to find the right 2.25" exhaust system but not sure about which exhaust manifold to mate it up with. I've read too many negative articles about cracking in Banks exhaust manifolds to confidently pull the trigger on their product. I've looked at other exhaust manifold manufacturers but it can be overwhelming. So my question to the community is: what's your experience and/or recommendations for the ideal stroker exhaust system. Thanks in advance for your engagement.
Re: 2.25" Stroker Exhaust Manifold / Exhaust System Recommendations
Posted: January 29th, 2026, 11:33 am
by Cheromaniac
It depends on the spec of your stroker engine. Ford a mild 4.6 that puts out up to 250hp (crank), a 2.5" exhaust from the header collector back would suffice.
