First Post — Basic Question
Posted: August 2nd, 2025, 10:36 am
Hey, y'all…
I got a 2003 Wrangler Sport that is pretty well built, but with a stock 4.0L — that I may have ruined…
I am now sixty years old and have been having some really bad health issues for years. I was in the process of starting a rebuild on my engine when I was hospitalized for a bit. I had to stop work, which was in May of 2018, so a little more than seven years ago.
Why does this matter?
Because I left the dang valve cover and oil pan off all this time!
Honestly, I thought I was gonna die, or at least never be able to go wheeling again, and the effort to put them back on after two weeks in the hospital when I was so weak was too much.
And with life crowding back in, trying to push me to catch up with all my responsibilities, I just sort of… forgot. After a certain amount of time, I thought that this would be an excellent excuse to do an LS swap, so I saw no need to get under the TJ and risk a heart attack just to button up a block I was going to ditch.
So it sat. And is it still sitting like that? I have the fenders off, but the hood is down, and towels are on top of the valve train, and they remain dry to this day.
The bottom is open to the air, and the oil dried up YEARS ago. However, I do not see any rust on the exposed parts of the cylinder walls. The crank turns without any unusual sounds, but I have not tried to turn it more than about 25º or 30º. So there may be a lot of rust between the pistons and walls. I am shocked by the lack of rust, to be honest. I am in Mississippi, where it is always humid, and the winters will see a few nights in the single-digit temps.
So, I want to pull the block this October when it cools down, now that my health and strength have improved. I want to drive my TJ baby again, so I have to fix my mess. I plan to put the 4.0L on my engine stand and strip it down for a visit to the local machine shop.
I am planning to do a 4.6L stroker job, but am worried about pitting that I cannot currently see or feel with it in the jeep. If I have to bore it 60 over and do the 4.7L job, will this make the block… "fragile"? And can pitting be so bad that my block is ruined? How viable is sleeving a 4.0L block? I know this can be common with clapped-out V8s, but it seems this block has less space between bores. Is this my imagination?
If I have to go the route of sleeves, would it be better to seek out a junkyard block?
I need to make some decisions, and I guess I need to shut up and pull the block to see what's up with it…
Any recommendations for a solid and honest machine shop in central Mississippi?
Help!
Aiden
Help!
Aiden
