What is the 4.0s breaking point?
Posted: March 2nd, 2024, 12:50 am
Hey guys,
Whats considered the 4.0s weak point?
I'm currently in final stages of machining for my build which I'll detail a little below.
It's not a stroker (sorry, I'm here because it's a tech based forum not for stroker specific info).
The combo is as follows:
NVH Block 30 though over.
Block decked.
Forged pistons.
Eagle rods./ARP Bolts
Factory Crank.
Fully balanced rotating assembly.
Crank tunnel aligned.
TUPY head professionally ported.
LS1 valves and springs.
ARP Headstuds.
MLS gasket.
Clegg stage 2 cam.
Duration 269 Intake | 273 Exhaust
Duration @ 0.050 Valve Lift 215 Intake | 219 Exhaust
Valve Lift 0.484 Intake | 0.480 Exhaust
Lobe Seperation Angle 114 Degrees
Double row timing set.
PSR GT3582 roller bearing turbo with 1.01 exhaust AR
GFB 44mm waste gate.
Aeroflow air to water intercooler.
I haven't bought the roller rockers yet, I'm on the fence now wether I go 1.6 or step up to 1.7 I need to speak to my engine machinist about the combo and seek their opinion.
The car has supporting mods for fuel, engine management etc. I originally built the turbo set up on the stock internals but have now gone bigger on the turbo, intercooler and of course internal airflow potential.
While I have no idea what it will make powerwise I am unable to find any suggestions as to what the 4.0 weak point is? Where does it show? I know Keith Newcomer lifted a head at 1000hp and Rick Mudge says they have that timing chain harmonic but that's about it. FYI I started building this motor due to timing chain failure
What's the consensus on safe power limits for these? Not for one dyno pass or a season of racing but as a weekend cruiser that can take the occasional burst?
Vid below of the original build.
https://youtu.be/c0a-dz1GB20?si=03fRxcYwK3sLInaC
Block decked.
Forged pistons.
Factory Crank.
ARP Headstuds.
MLS gasket.
Clegg stage 2 cam.
