High fuel pressure and idle at 1500
Posted: April 27th, 2023, 1:31 pm
93 yj, 4.6 stroker,Was driving around in the sand on the beach for the day and I was running pretty hot almost at redline but never to it, anyway I think I that is unrelated, on the short trail back to the road my check engine came on and started idling at 1000, I have a afr gauge as well it was reading 9-10, pretty rich, go park to air up and start back up, idles at 1000, and about 14.7 on the afr gauge, it was kinda jumpy, the next day I try it out, it idles at 1500 now, the checks I have done, I'm getting codes 52 and 21, because I'm running rich I already new that, I have a fuel pressure gauge on my rail it reads 60psi with the regulator hooked up and disconnected at all rpms, and drops right back down to nothing right when the vehicle is turned off, I know this is way wrong, my understanding this is most likely not a electrical issue/bad sensor making my fuel pressure high, the fuel system is all mechanical, what would be the logical thing to do/troubleshoot next, I pretty much restored this thing in the past 2 years, new fuel lines all the way back, all new sensors along with the stroker build, and Axle upgrades, but I know new things can go bad too
