water temp sensor causes header to glow
Posted: March 28th, 2023, 10:54 pm
by geeknahalf
Hi Folks,
I'm stuck.
I have a 2004 jeep wrangler TJ, and I recently built a 4.6 stroker and I'm experiencing an odd issue. When i plug the water temp sensor in (it's a new unit), it runs great for about 5 minutes then goes down hill. The eng runs rough, stumbles, gurgles in the muffler, runs like crap, has zero power, and the exhaust glows red. In essence, it's completely undrivable. I have a lot of money tied up into this and don't want to ruin it.
I have replaced the entire exhaust so no restrictions there. Its a 99 wrangler exhaust which only comes with two O2 sensors, so I relocated the remaining O2 sensors required for the 04 next to the factory locations on the 99 system, upstream/down stream respectively.
The timing is set properly as far as I can tell- on TDC compression stroke and the cam sensor lines up according to the alignment tool (no hole to use, they include a cap that aligns the placement)
If i unplug the coolant temp sensor the jeep drives enough that i got it home from the mechanic shop, and the exhaust doesn't glow. They couldn't determine the cause...
I'm sure there's information I'm forgetting, but I'm at such a loss and burnt out that I cant think straight so please ask questions.
Before I made the swap, the jeep ran great.
Any guidance would be greatly appreciated.
Me
Re: water temp sensor causes header to glow
Posted: November 3rd, 2025, 9:21 pm
by mpgMike
This is an old post, but I know folks use the "Search" feature when they have issues, so there may be some that find this post wanting answers. To me the answer is probably a CTS (Coolant Temp Sensor) with different calibrations. I have a '95 ZJ, so I have the '95 Service Manual. However, it outlines what the resistance value should be at various temperatures. A good test would be to find that chart for your 2004, measure the resistance across the CTS and see if it's any near what the FSM chart states.
