NEW stroker project for 98 TJ
Posted: May 15th, 2022, 9:08 pm
Started my stroker project 1 month ago for my 1998 TJ. Questions below a brief plan summary:
1998 #569 4.0 block, previously bored .040, at my machine shop now. Expect .060 overbore (4.7L)
0630 head is cracked between #3 &4 combustion chambers on deck surface—considering replacements
New stroker crank-3.895
4.0 6.123 rods-considering reuse mine vs new
Considering Hyperutectic and Forged pistons (21-27 cc dish)
Target 9.25-9.3 static, 8.0-8.1 dynamic cr. Using Jeep Stroker Calculator—cool!
Considering camshafts (maybe 68-232-04 but prefer Nitrided).
99+ intake in transit-I will modify for my vacuum and manifold temp sensor
63mm bored Throttle Body by Jeff Leigh—pre-teardown installed and tested
CRT Performance power boost cap, rotor, wires and coil—pre-teardown installed and tested
Factory EFI and computer.
Larger , 4 hole injectors, perhaps Bosch 0280155703, 715 or custom by Fuel Injection Connection
Working with my machine shop and help from Russ Pottenger on reciprocating assembly, deck and cylinder head design.
Questions on other engine parts for this stroker:
1) to use my factory EFI and ECM, should I use a 4.0 flywheel and crank position sensor?
2) Can I use a 4.0 harmonic balancer?
3) I’m building a big shopping cart on rock auto for other replacement pieces normally used in rebuild-Melling std volume oil pump, timing set, cam bolt plunger &spring, gaskets, GMB high perf water pump, LUK HD clutch kit, etc.
Any input on these parts?
4) any input on above overall plan?
My last engine rebuilds were in the 70’s and 80’s. I’ve done Cam swaps, heads, carbs, manifolds, headers, etc over the years. I’m always wrenching on something. I’m enjoying this project Jeep.
Thanks for help,
TJBUD
Additional: Ax15 rebuild complete by local shop, I’m in middle of the 231J rebuild.
Jeep has 207K mi, 33x12.50 tires, 3.73 gears, 2-3” lift.
Powerstop Brakes
Thanks for help,
TJBUD
Powerstop Brakes
