Transmission Needs
Posted: August 13th, 2021, 8:40 am
I did attempt to search for information on how to approach the transmission work that will be needed once the stroker is complete but have not seen much. I am going with a 4.6 build, the RaceTech Pistons are here, and the machine shop will be boring the block and installing the cam bearings next week. Now that I have a path forward for the engine, I would like to make preparation plans for the transmission. It is a 42RE and seemed to work pretty good at the time I pulled the motor. The main issue was that it had some bad leaks.
Is a normal rebuild appropriate and will it handle the added HP and Torque from the Stroker? As far as the Torque Converter goes same question, is stock ok or is it better to match it to the new cam? What information will I need to match the two? Thanks again!
