4.2 harmonic balancer
Shrek
Vehicle Year: 1989
Post by Shrek »
I have a 89 4.2, and would like to convert form a "V" belt to a serpentine belt.
Will a 4.0 harmonic balancer fit and function on my 4.2 crank? I am in the process of putting a 4.0 head on a rebuilt block.
TIA
rlinares40
Where's the "any" key?
Re: 4.2 harmonic balancer
Post by rlinares40 »
Shrek wrote: June 18th, 2021, 8:41 am I have a 89 4.2, and would like to convert form a "V" belt to a serpentine belt.
TIA
I would believe so as we can use your crankshafts on our 4.0s. where I can see you running into the problem is with the accessories, they are driven by a "V" belt pulley correct?
rlinares40
rlinares40 wrote: June 18th, 2021, 9:50 am
TIA
meaning it does no good to have a serpentine harmonic balancer when your alternator pulley is "V" styled.
Shrek
Vehicle Year: 1989
Post by Shrek »
Thank you for the reply. :cheers:
I am changing the power steering pump, water pump, and the alternator to a serpentine belt. An idler pulley will need to be installed as well.
I spoke with Russ Pottenger, and found that I can use a 4.0 balancer, but will need a spacer, which I purchased from him.
Azhunter
Post by Azhunter »
If you use the harmonic balancer for the 2.5 4cyl. it is the same part number as the 4.2 serpentine balancer and everything will line up right and you wont need the spacer.
Users browsing this forum: No registered users and 33 guests
