First stroker, 4.6L
Posted: September 17th, 2020, 4:35 am
New here, but not new to the Jeep life. I have a 96 XJ that I'm planning on swapping in a Golen 4.6L stroker that I got an insane deal on from a good friend of mine. I would think the swap will be pretty straight forward, but am looking for advice and mabey some things I should do to prep the jeep for the added HP.
Currently have a basically stock 4.0 with the Bosch 12 hole 24lb injectors from K-suspension (#0280156161), a cowel/cold air intake, and high flow catalytic converter. I have a new set of Brown Dog motor mounts for the 4.6 along with a 99+ intake manifold that has been port matched. I'm wondering how well these injectors would work?
I've also been looking into the oil filter adapter, the block on this 4.6L is a Renix generation, I'm wondering if its possible to swap the oil adapers between the Renix block and HO block? If not I have heard of clocking the Renix adapter 90*? I know its possible to change the Renix adapter to the HO threads.
