2000 XJ Stroker NEW
Posted: June 21st, 2020, 2:11 pm
I'm in the middle of a tear down on my 2000 XJ my original plan was just to reseal with new gaskets, timing, and a clearwater head and put her back in until it died (currently 138K miles). However I was able to get a 4.2L crank (casting# 3214723) for $50 dollars locally on marketplace and I figured I would be dumb to pass that up. I'm looking for some suggestions to stay within budget I figure if i spend anymore than $2500 I could at that point basically just buy a titan stroker kit straight out.
Following the machine work FAQ post = $1095 in machine cost (seems like a lot for machine work)
Block:
1. hot tank or oven bake. (cleaning) $75 to clean, shot blast, and mag block
2. shot blast.
3. magnaflux. (check for cracks)
4. line hone the main bearing bores if needed. (I would recommend this for bearing clearance) $150
5. bore and hone to desired size. (I.E. over .030) $250
6. check deck for flatness if not milling, if milling tell them how much. (I.E. have .030 decked off.) $75
7. Install cam bearings. $25-$30
Crankshaft:
1. hot tank or oven bake if dirty. $25
2. grind mains and rods to desired size, or offset grind if desired. $125
2a. Chamfer oil holes if desired. (better oiling) $25
3. spin balance. (optional) $50
Connecting Rods:
2. shot peen if desired. (for strength) $30
3. check for straightness. $15
4. install rod bolts if desired. $25
5. resize bearing journals. $125
6. weight balance. $20
7. install pistons. $50
The for remainder parts
clearwarter head - $600
Gasket set - $100
Pistons - $400
258 crank - $50
So Im already at $2195 here without bearings, oil pump, freeze plugs, timing chain, camshaft. I'm starting to think https://titanengines.com/jeep-strokers/ ... o-4-6-4-7/ this kit seems like a really good value and maybe I should just sell off the crank I bought.
Also questions on heads does a standard head work just fine with a stroker or does it need different valves, porting, etc? Basically if I bought a clearwater head can I just slap it on the stroker and go? I also have the 12 port bosch injectors from K suspension would those be able to be used or would I need even more flow?
Any guidance on why I should or shouldn't use the titan kit or where I can save some money on this would be appreciated... I thought when I found the crank so cheap I was ahead of the game but it doesn't really look like it.
Block:
2. shot blast.
Crankshaft:
Connecting Rods:
Gasket set - $100
Pistons - $400
258 crank - $50
