Pushrod question
Posted: June 12th, 2020, 5:11 pm
by Abecheese
While I'm waiting for the cam kit to ship do any of you guys know the correct pushrod length for the lunati 262/268 camshaft?
Re: Pushrod question
Posted: June 14th, 2020, 12:32 am
by Cheromaniac
Your best bet is to buy a pushrod checker tool to measure the required length.
Posted: June 14th, 2020, 7:14 am
by SkylinesSuck
Yes, measure, don't guess. I was shocked when I measured mine. Long story, but don't assume.
Posted: June 14th, 2020, 7:16 am
by SkylinesSuck
And I'll say further that your deck height, how much has been milled off the head, and cam base circle affect the required length, not lift/duration of your cam.
Posted: June 14th, 2020, 6:46 pm
by KarmaKannon1
Does someone have instructions on how to check pushrod length?
Posted: June 15th, 2020, 12:43 am
by Russ Pottenger
KarmaKannon1 wrote: ↑June 14th, 2020, 6:46 pm
With the cam on the base circle (heal of cam) the plunger in most lifters should be depressed .040 to .080
As previously mentioned an adjustable pushrod will make this task much easier to measure.
Comp Cams makes a pretty spiffy pushrod checker #7704-1
