High stall converters
- Stroker Displacement: 4.0
- Vehicle Model: Grand cher
Hello all I’m looking for people who have installed high stall converters
Re: High stall converters
Ive installed a higher stall in a 91 supercharged chevy truck. Don't think I need it in my soon to be built stroker cause I don't plan on drag racing it.
- Vehicle Year: 2004
I'm curious how you are using your vehicle to need a high speed converter. Loose converters create a lot of heat. How high are you thinking?
That is true but usually with high stall most people install a oversized cooler anyway. Im sure he doesn't want a 4000 stall either lol. Usually a 500 rpm over stock will suffice with improved 0-60mph times not make too much more heat. My truck was a 2500 stall and still retained the lock up feature in the torque converter.Brianj5600 wrote: ↑May 20th, 2020, 12:54 am I'm curious how you are using your vehicle to need a high speed converter. Loose converters create a lot of heat. How high are you thinking?
Thanks for the reply’s my 99 wj has 4.0:supercharged. I was thinking about 400 rpm increase
I run two 58 stack transmission coolers,I’ve never seen temps past 180.I also run a pml deep transmission pan, 9 quarts to fill.i plan on doing a lot more wheeling .I have a 4inch lift 33 inch tires tru trac front and rear with 488 gears.Brianj5600 wrote: ↑May 20th, 2020, 12:54 am I'm curious how you are using your vehicle to need a high speed converter. Loose converters create a lot of heat. How high are you thinking?
There use to be a place in cali called The Converter Shop (TCS). They could cut open your stock converter and modify it to slip a bit more giving you the stall you want. While they are in there they can up grade bearings and anything else. Look them up and see what thet can do for you. Post up your findings.
This is my transmission cooler setup
Make sure you protect the trans pan if you plan to wheel it, a deep pan sounds like it’ll hang down some grabbing rocks.6sense wrote: ↑July 12th, 2020, 5:22 pmI run two 58 stack transmission coolers,I’ve never seen temps past 180.I also run a pml deep transmission pan, 9 quarts to fill.i plan on doing a lot more wheeling .I have a 4inch lift 33 inch tires tru trac front and rear with 488 gears.Brianj5600 wrote: ↑May 20th, 2020, 12:54 am I'm curious how you are using your vehicle to need a high speed converter. Loose converters create a lot of heat. How high are you thinking?
Connecting heat exchanger in series is not a good idea. Parallel works much better, although much more work to do it. (2x T splice)
The trick is in the flow resistance:
When you have coolers in parallel, you have half the resistance, you increase oil flow, you have more mass flow on double surface
When you have coolers in series, you increase your resistance, you get less flow, your pump is working harder and maybe you have slightly better cooling in total than with single exchanger.
I have seen this mistake on industrial equipment - and results were not good. (mildly speaking) Just redo the piping and you will have much better results.
°O|||||||O°
I guess it’s the way the picture looks but it’s not in series it is parallel,I incorporated the radiator,I’ve had this setup over a year and I have never gone past 180.I also use a PML deep transmission pan.
Users browsing this forum: No registered users and 29 guests
