which cps sensor on new stroker
So im picking up my engine in the next couple days and going to get it installed this week but while i am in the process i have replaced every sensor but the only thing im not sure about is whether or not to run the standard cps or high altitude. I have both but since it is a pain to get to i want to put it in once if i can.
Re: which cps sensor on new stroker
You could slot the bolt holes of the stock CPS and make it adjustable.
I have one that is a high altitude but I don't know if its going to benefit or not so not really a need to slot holes.Cheromaniac wrote: ↑April 28th, 2020, 1:08 am You could slot the bolt holes of the stock CPS and make it adjustable.
So the question is do you want appx 6 degrees of base ignition advance? Sure why not I liked mine.
So it looks like i will be using it then
