Oil pressure on fresh build?
Posted: April 25th, 2020, 7:38 am
Hello all, not sure where to put this, but this seems like a good enough place.
I recently built a 4.5 (ish) stroker. Used a 98 block (bored .020 over), 94 head (machined for flatness only), 2000 intake manifold, mild Comp Cam (252 grind?), and a late 80's 4.2L crank (.020 under) and rods (.010 under). The crank and rods may be backwards on cleanup grind. I reused my 92's stock exhaust and I believe the stock oil pump from the 98 block (out of Grand Cherokee).
I finally got everything in and ran it through the 30 minute 2000-2500 RPM break-in in the cam instructions. The pressure stayed somewhere between 60 and 80 PSI on the gauge. I changed the oil and filter and have driven it about 130 miles to this point. I'd like to know what you guys have seen as your oil pressure on a freshly built engine. My gauge is reading above 60 PSI under load and around 40 PSI at idle running conventional 10w30 oil.
I have a rear main leak as well. I'm positive it is the rear main as the oil is coming out between the back plate and transmission bell housing and the back and sides of the engine are bone dry and clean, including the back of the head where it meets the block. It wasn't leaking right away, I checked under the Jeep a few times during the break-in when checking to make sure the new radiator's coolant level was correct and the electric cooling fans were working. I'm guessing it happened after the 20 minute mark. I'm not sure if I rolled the lip on the seal or if high pressure caused it to fail. Either way, I've already lost at least a quart of oil.
