It's ALIVE!!!
Posted: January 9th, 2009, 9:53 pm
Hey Jeepers,
Well, my stroker is on the road!
I am one of the unfortunate Jeep owners who has to pay to have the work done. No shop, no time, no tools
Anyway, I went to the shop where it was being installed, and it was sitting in the parking lot ready to be fired up. Fluids in, everything hooked up. Popped the hood and saw one connection hangin' loose. Ended up being the IAT connection. Found the old sending unit in the back, stuck it in. So...turned the key and...IT FIRED RIGHT UP!
NO PROBLEMS. Ran it up to 2000 rpms for 20 mins. and then 500 rpm increases to 3500 for one minute each, then back down to 1000 rpms, 500 at a time for one minute each. That was Lunati's procedure. At the end of the break-in, the temp. had gotten high and it blew off the bottom radiator hose. Tightened the hose back down, filled it back up with coolant and burped the air bubbles. Fired it back up and it settled in to a nice smooth 700-750 rpm idle. NICE. NO LEAKS.
Issues- The oil pressure gauge acted up, flippin' all over the place. Turned out to be the sending unit. Loose or crappin' out. No biggie.
Weird-It runs REALLY COOL. Goin' down the road, it only shows about 125-150 on the gauge. It takes about 20 minute setting in place for it to get up to 180-190. The mechanic used a thermal gun on it yesterday and it indeed showed 175 at one end of the engine and 200 at the other end. It is SOOOOO quite too. My old 4.0 had a cam, header, RR's, T-Body, etc, so it was reasonably strong, but it was NOISY! The lifter had been on it's way for a long time and I just got used to the noise. My stroker is as quite as a stocker, accept for the exhaust note
I am using the Hesco H2O pump, Robert Shaw 180 thermostat, Turbo City high flow T-Stat housing, and a new radiator. Is it possible it just VERY efficient? Works great so far.
Driving-Well, like I said my 4.0 was pretty strong , even with the bad lifter. I haven't really stomped the pedal either, since it's so new. But it feels REALLY smooth and it now holds overdrive going up hills that it would have QUICKLY shifted down to be able to climb. It has a resonance that I can feel through the whole vehicle. I'm lookin' forward to gettin' the break-in completed and being able to stretch it out a bit.
Build-
*Original '94 XJ engine
*4 wt. 258 crank, stock 4.0 rods, ARP rod bolts, KB 9.0:1 forged pistons. Crank, rods, pistons, and flex plate balanced.
*Block bored .60 over, zero decked, hot tanked, lined bored, bottom end girdle fitted.
*Head fitted with .160/2.02 valves, Mopar 5.2 springs, extensive porting and bench flow work, flows 247 cfm at .500 intake, 158 cfm at .500 exhaust, combustion chambers reduced to 58 CC's.
*Lunati Voodoo cam, 484/507 lift, Yella Terra RR's, chromo pushrods.
*Hesco oil pump, H2O pump, and fuel pressure reg.
*Cloyes true roller timing set.
* '99 intake conversion, #24 Ford blue top injectors, 62MM Fastman throttle body, K&N cold air.
*Full MSD ignition brain, coil, wires.
*Doug Thorley stainless, ceramic header. NO problems with mine.
The simulator on the site gave me a static comp of about 9.6:1 with around 8.23:1 dynamic. Quench is .040-.045.
I is an expensive build, but so far it RUNS GREAT
Thanks for all you input. Will keep ya' posted. Any thoughts on the cool running?
crust1
Build-
crust1
